lsx swap question
Old Jun 26, 2009 | 11:40 AM
nubucks's Avatar
lsx swap question
is it possible to put an ls engine in my 97 z28. i know that im going to have to buy the computer for the ls engine and the wiring harness and etc but is it a difficult process
Old Jun 26, 2009 | 11:52 AM
Bersaglieri's Avatar
With all the LSX swaps lately you would think this is posted somewhere, maybe not. But yea, it can be done, it's going to take alot of work, but not hard work, just time. Probably need an LSX K member and all that jazz too.
-Dustin-
Old Jun 26, 2009 | 11:58 AM
nubucks's Avatar
is it an expensive process
Old Jun 26, 2009 | 12:06 PM
Well that depends how much you can get the LSX motor for, if it's an Fbody one or if youll need a different intake [if its a truck motor], obviously the wiring and PCM, plus if your using a stock K member vs a $500 aftermarket one, etc. I'm sure folks who have done it can chime in and give you some tips and info.
-Dustin-
Old Jun 26, 2009 | 01:35 PM
ssclone's Avatar
ls1 k-member,
ls1 rack and pinion and ps pump
ls1 gas tank, and fuel pump
something about the lines, and the gauge not working either
the harness, some dash stuff might not work (i cant remember)
some other stuff too.
i personally dont think its too bad, but i swapped many many motors. but it is a difficult task.
check over at ls1tech.com in the hybrids and conversions forum. and do a search
good luck
aaron
edit..
also need an fbody/vette intake or aftermarket, fbody oil pan, fbody accessories.
you can find all this stuff used on these forums.
Old Jun 27, 2009 | 01:28 AM
qnitro's Avatar
way more work than its worth.. I know... Need front engine bay harness, the one with the relays and lights... need to swap A/c box if you want A/C. Need to swap dash wiring harness... need to swap gas tanks...need k-member LOTS of works... but if you have a complete doner car as I did its a fun weekend...
Old Jun 27, 2009 | 07:45 AM
David94TA's Avatar
Here you go:
http://www.ls1tech.com/forums/conver...body-help.html
http://www.ls1tech.com/forums/conver...to-95-z28.html
http://www.ls1tech.com/forums/conver...-ls1-swap.html
Old Jun 27, 2009 | 09:27 AM
<Puck>'s Avatar
You do not need a new gas tank. Just have to change the regulator setup.
Old Jun 28, 2009 | 04:24 AM
BlackBird97's Avatar
I have had a few friends swap over to an LSX type motor. It cost them ALOT of money. If you are serious about swapping, look into selling your car and just buying an F-body with an LS1 already in it. Saves a lot of head aches, unless you are very attached to your car.
Hotrods&Muscle
Feb 18, 2015 06:38 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
