Lsa ?? On A Xe230/236 Which Would Be Best For Me 112lsa Or 114 Lsa
Old Dec 21, 2003 | 07:45 PM
  #16
96ssz28#395's Avatar
So no problem with the brakes or other key things you need vacuum for? Even in heavy traffic at idle? Thanks For Your Time. Mike...
Old Dec 21, 2003 | 08:17 PM
  #17
dnz28's Avatar
If you want vaccum go buy a hoover
Old Dec 21, 2003 | 08:26 PM
  #18
No i will just order the container the same time i order the cam. It would be nice if you could answer the question.I see in your sig. that you have this cam as well help would be greatly approved. Thanks For Your Time. Mike...
Old Dec 21, 2003 | 09:49 PM
  #19
dnz28's Avatar
okay okay I will answer my vaccum is fine, when you first install it you vaccum will be okay something you can live with but get a tune and have your idle raised to around 900to950ish and it like stock plus the extra chop and power. I would go with the 112lsa I peak out around 6300 which is not bad on the stock bottom end. I think 114 would peak out around 5800 to 6000 depending on head work. hope that helped you out.
Old Dec 21, 2003 | 10:40 PM
  #20
Now that is the kind of info i am looking for.Thank you very much.After you got a tune on your pcm. Did you have the smelly fume problems alot of people talk about? Thanks For Your Time. Mike...
Old Dec 22, 2003 | 10:12 AM
  #21
dnz28's Avatar
well a little when i popped the hood but, nothing bad kinda makes your car smell like a carbed car. As for my exhaust though i run straight pipe so i smell everything, since you seem to have lots of questions since this in a a4 i will let you know if you dont get a tune right away you are going to have to throw your car into neutral at stop light and rev it up, because you car will die. great cam I love it not much below 2000rpms but after that it pulls hard.
Old Dec 22, 2003 | 02:03 PM
  #22
That is sorta what i was thinking. I do have headers as well but i have the slp TOTL with a custom y pipe i do have hi flow cats already.Im thinking that with my 2800 stall this thing should really jump pretty good out of the box. As for the pcm tune that is the first thing i have planed,atleast untill i can get a dyno tune.Thanks i can really use this kind of input. Thanks For Your Time. Mike.......
Old Dec 22, 2003 | 07:23 PM
  #23
llafro's Avatar
Vacuum is low, but will work.
I don't have any problems with vacuum or anything else with the 112 lsa on my car. It runs pretty much like stock at low RPM, but pulls really well up high. I have a dyno tune on it, so it runs pretty well.
Old Dec 22, 2003 | 07:47 PM
  #24
That is what i plan on doing is a dyno tune right away. Thanks For Your Time. Mike.......
Old Dec 23, 2003 | 05:22 AM
  #25
kcsoz20's Avatar
Thumbs up No vaccumn probs here....
I run an A4 with a vigi 2800 stall and run the 230/236 112. I have never had any issues with vaccumn or low rpm idle stalling problems. Cam is bad, sounds bad and moves the car. Go for it and have fun with it.
Ken
Old Dec 23, 2003 | 10:57 AM
  #26
Thanks Ken. Those numbers in your sig. Are right around where i want to be with my car that is very impressive for an A4 car.Thanks For Yor Time. Mike....
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
95craz28
11
Sep 12, 2015 07:47 AM
Schul365
Aug 25, 2015 05:47 PM
birdblack
Jul 8, 2015 07:23 AM
