lsa Q. 111 + 2 ???
Old Mar 25, 2005 | 10:28 AM
Mystic97Z's Avatar
lsa Q. 111 + 2 ???
ordered a cam yesterday, c motorsports recommended a
111 + 2 lsa
what's the + 2 ?
Old Mar 25, 2005 | 10:43 AM
flyinZ's Avatar
Re: lsa Q. 111 + 2 ???
It means, 2*(degrees) ground in..From what I've been told, it has to do with the powerband...somehow.
Old Mar 25, 2005 | 10:46 AM
97bowtie's Avatar
Yes, +2 means there are 2* of advance ground into the cam. The ICL (intake center line) on that cam is 109 (109 + 2 = 111 LSA). LT1 cams typically have 4* of advance ground into them, but seems cam designers are moving in other directions and trying different things. Having 2* of advance will shift your peak power upward in the rpm range a little, as opposed to a +4 cam.
Old Mar 25, 2005 | 11:19 AM
Mystic97Z's Avatar
ya i do remember him saying about advance, cuz i was wanting to with 110 lsa but the powerband would be higher than i wanted.
Old Mar 25, 2005 | 11:24 AM
97bowtie's Avatar
You could go with a 110 LSA and a 108 ICL...this would give you the same 2* advance. The 110 LSA will give you more overlap which will make the car 'lope' harder. The 110 LSA might give you a couple more peak HP than the 111 LSA, but your torque curve would be a little peakier than with the 111 LSA.
Old Mar 25, 2005 | 12:00 PM
Mystic97Z's Avatar
well u want it to chop/idle as radical as possible. i had a
22x/23x cam before on 110 lsa and it was decently radical idle
my new one is 23x/24x with a lil higher lift on 111.
will it have a smoother idle?
but with the duration higher, powerband moves up right? which was deffinately takin into consideration. i talked to dave at cms and he was very helpful,
Old Mar 25, 2005 | 12:04 PM
97bowtie's Avatar
The 23x/24x on a 111 lsa will have a more radical idle than the 22x/23x on a 110 lsa due to the considerable increase in duration. Neither will idle smooth. The 23x/24x should peak higher and make more peak hp than the 22x/23x.
Old Mar 25, 2005 | 02:08 PM
Mystic97Z's Avatar
thanks for the help, though the guy said the larger duration #'s wouldn't change the idle.
Old Mar 25, 2005 | 02:13 PM
97bowtie's Avatar
Duration absolutely affects the idle. Duration affects overlap which will change the idle characteristics. He may be saying the change in duration won't have a huge affect on how the car idles, but it will have some.
95chwagon
Oct 16, 2015 12:24 PM
95craz28
11
Sep 12, 2015 07:47 AM
Schul365
Aug 25, 2015 05:47 PM
13qtr
Jul 19, 2015 05:30 PM
birdblack
Jul 8, 2015 07:23 AM
