LS7 Lifter Dramatically More Shallow (with pics)
Old May 28, 2009 | 05:58 PM
Hal Fisher's Avatar
As you can see in the pics the LS7 is dramatically more shallow. I mic'd them and it appears at least .05 different. Now if you're running stock rockers then it probably doesn't matter but if your running 1.6 then it is certainly going to be too close to the outside edge of the valve head. The body, roller, and clip appeared exactly the same as stock, only the pushrod portion is different.
Ls7 on the left, stock on the right
Some LS7 lifters were lighter colored, some were dark like the stock lifter (dark stock lifter on the left)
Hal
Old May 28, 2009 | 08:32 PM
wrd1972's Avatar
Yup, I noticed this too.
Old May 28, 2009 | 08:48 PM
RamAir95TA's Avatar
Same here!
Old May 28, 2009 | 09:07 PM
ACE1252's Avatar
Nice to see the difference.
Old May 29, 2009 | 02:36 PM
65MalibuSS's Avatar
Can you put LS7 lifters in an LT1?
Old May 29, 2009 | 02:46 PM
Stl94LT1's Avatar
Yes.
Old May 30, 2009 | 08:04 PM
BLKOUTZ28's Avatar
They work fine in mine.
Old May 31, 2009 | 05:28 PM
Hal Fisher's Avatar
Well here is a pic with both 1.5 and 1.6 rocker marks. Strange, but it seems close enough to me.
1.6 on the left, 1.5 on the right.
Hal
Old May 31, 2009 | 05:50 PM
bombebomb's Avatar
They are the stock replacement for LT1's now.
Old Jun 1, 2009 | 01:41 PM
meissen's Avatar
I'm running LS7 lifters in my build right now with stock length push rods. LS7 lifters, comp cams hardened pushrods stock length, comp cams pro mag 1.6 roller rockers, fel-pro head gaskets, CC503. I went with them and stayed with stock pushrod length after I read on here that someone else was using stock pushrod length with the ls7 lifters.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
dfarr67
Apr 10, 2015 07:44 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
