LS7 Lifter ?
Old Feb 19, 2008 | 12:28 PM
  #31
krillformula's Avatar
Originally Posted by mdenz3
The cup depths are different. I compared them when I installed them, there is about a 0.1" difference in the cup depth.
If you don't belive me:
http://ls1tech.com/forums/showpost.p...6&postcount=11
To the OP; Get the stock LS7 lifters when you install them check your pushrod legnth and then order the correct ones. You will need to do that anyway if you are going to upgrade to better rockers too.
This is true. I measured them on my install to.
Old Mar 9, 2008 | 09:56 PM
  #32
ssean92's Avatar
what size did you end up using, the ls7's are deeper so you would need a longer on right for stock? I measured 7.165 using a lt lifter so should I add or subtract from that for the ls lifter? that is using the pro mag RR to
Old Mar 10, 2008 | 11:32 AM
  #33
Plague's Avatar
Originally Posted by Javier97Z28
Did you check your valvetrain geometry to make sure?
Originally Posted by '94 Bad A Z28
Yes, everything is perfect.
Maybe so, but a GM Master Tech is the one who installed them for me and everything is perfect.
So, if a GM Master Tech installed them, did you check the geometry yourself or just let him say it was "ok" ???
Old Mar 10, 2008 | 02:22 PM
  #34
Airbornec507's Avatar
I just finished installing the caddy lifters and my geometry seems to be fine after my spring switch over as well(to PAC 1218's). The head of the Comp Pro Mag RR always stays in constant contact with the valve stem tip but realy doesn't move a whole lot from one side to the other(just a bit that's hardly noticable which is expected). It doesn't travel however over the entire valve stem tip like some diagrams I've looked at.
Old Mar 15, 2008 | 04:46 PM
  #35
Drop Top's Avatar
Anyone have a part # for the LS7 lifters?
Old Mar 15, 2008 | 07:04 PM
  #36
ACE1252's Avatar
Exactly what is the advantage to these LS7 lifters vs. the stockers in the LT1?
Old Mar 15, 2008 | 07:22 PM
  #37
2000GTP's Avatar
There is no real advantages over the stockers other then being a cheap aftermarket replacement.
Old Mar 16, 2008 | 09:00 PM
  #38
maverickmk's Avatar
why would you question someone who does this for a living? I don't understand why your questioning this (?)
Old Mar 16, 2008 | 09:53 PM
  #39
Because people make mistakes or just don't know what they ought to.
Old Mar 17, 2008 | 07:14 AM
  #40
2000GTP's Avatar
Not too mention a GM master tech may know his way around the GM platforms, sure, but he may not up and up on all of the aftermarket stuff.
Old Mar 17, 2008 | 07:22 AM
  #41
maverickmk's Avatar
so, someone who builds a motor once every few years is going to be better than someone who works on cars/motors for a living?
Old Mar 17, 2008 | 07:24 AM
  #42
dangalla's Avatar
half the guys that work in my shop i would not trust to build me a paper air plain let alone an engine, and they are all ford master techs
even if they were the best tech they may not know much about interchanging parts between models like that or just aftermarket parts in general
Old Mar 17, 2008 | 07:38 AM
  #43
2000GTP's Avatar
I wasn't implying that, but take this site for example. There are alot of people on here who have been first time builders and done so with success. Why, because they take alot of time to research the parts, specs, and procedure to do the job.
Old Mar 17, 2008 | 07:57 AM
  #44
'94 Bad A Z28's Avatar
Let's see, he has his own performance shop, works on LT1, LS1, LS2, LS6, LQ9, LS7 motors (amongst others) all day... yeah you guys are right, I should never have even trusted him with my car.
Old Mar 17, 2008 | 10:56 AM
  #45
It depends on where there experience lies. Engines in general are the same, but there are lots of things different between them. It's ok to trust someone based on their experience with whatever you have. Heck, I do all my own work and sometimes I have to look up something I might have forgotten.
On the rare occasion that someone else does something to my car (even dealer warranty), I still look over what they did. Not pointing anyone out or purposely being derogatory, I have seen self proclaimed ASE Master Techs post things that indicated a failure of understanding.
Point is, there are great techs out there and mediocre ones. You can't take any of them at face value.
