LS7 Lifter ?
Old Feb 18, 2008 | 01:48 PM
  #16
PWR-TRIP's Avatar
You wont notice any difference, but they're good high revving lifters.
Right Dangalla?
Old Feb 18, 2008 | 02:21 PM
  #17
Originally Posted by dangalla
all of you that said this, how do you know for sure? when i put mine in they sure looked different. i would guess you need a slightly longer pushrod but maybe adjusting the rockers can compensate
You can't compensate for geometry by making rocker nut adjustments.
Old Feb 18, 2008 | 02:26 PM
  #18
dangalla's Avatar
maybe i am thinking about this wrong but would'nt a little less pre-load on the lifter equate to a slightly longer pushrod. i guess i should have explaned it better.
and pwr-trip your pretty much right but i am really not sure as to weather or not it is a direct replacement, they look different.
Old Feb 18, 2008 | 02:50 PM
  #19
'94 Bad A Z28's Avatar
Originally Posted by mdenz3
Are we talking about the Caddy racing lifters or the stock LS7 lifters?
The stock LS7's are not a direct replacement. The cup depth is considerably different and you will need to measure and get the correct pushrods.
The stock LS7 lifter ARE a direct replacement.
Old Feb 18, 2008 | 02:51 PM
  #20
Originally Posted by Javier97Z28
Did you check your valvetrain geometry to make sure?
Yes, everything is perfect.
Old Feb 18, 2008 | 02:52 PM
  #21
Originally Posted by Rising Phoenix
Can someone confirm this for sure one way or the other, because I was thinking about getting these for my car.
They are in my car, and everything checks out perfect, that's all the conformation I need.
Old Feb 18, 2008 | 04:39 PM
  #22
a4z28's Avatar
Thank you i will get a set and try them.
Old Feb 18, 2008 | 05:56 PM
  #23
z28_theantirice's Avatar
Not sure the exact difference between the Caddy LS7 and the regular LS7 but the cup the pushrod sits in, in my Caddy LS7's was considerably shallower then my stockers. Thus requiring a shorter pushrod
Old Feb 18, 2008 | 06:42 PM
  #24
I thought it was Caddy or LS7 - not Caddy LS7.
Old Feb 18, 2008 | 06:48 PM
  #25
I say Caddy LS7's because the motor they are used in is a destroked LS7
Old Feb 18, 2008 | 06:53 PM
  #26
mdenz3's Avatar
The cup depths are different. I compared them when I installed them, there is about a 0.1" difference in the cup depth.
If you don't belive me:
http://ls1tech.com/forums/showpost.p...6&postcount=11
To the OP; Get the stock LS7 lifters when you install them check your pushrod legnth and then order the correct ones. You will need to do that anyway if you are going to upgrade to better rockers too.
Old Feb 18, 2008 | 06:59 PM
  #27
...makes it very confusing...
Old Feb 18, 2008 | 09:50 PM
  #28
Maybe so, but a GM Master Tech is the one who installed them for me and everything is perfect.
Old Feb 19, 2008 | 07:21 AM
  #29
dangalla's Avatar
that does not mean anything, unless your geometry was checked your giving nothing but miss-information in this thread. maybe you got lucky. i did not install just the lifters so i did not measure for just them, but they looked really different and i can only assume that they are different.
i have had them both in my hand, stock and ls7, and they look nothing alike in the cup area. without someone measuring and installing only the lifters no one here can be sure, and speculation in only going to end up with someone breaking there motor because joe schmo had them installed by a master tech so they must be fine.
Old Feb 19, 2008 | 11:40 AM
  #30
Mike94ZLT1's Avatar
The cadillac racing lifters and the LS7 lifters are not the same. And they aren't used in a destroked LS7. The cadillac racing lifters are the ones cadillac uses in their LeMans cars, and the LS7 lifters are the ones that GM came out with for the LS7. The older style LS1 lifters are no longer available, the new LS7 part number supersedes the others.
