LS1 vs LT1 Steering Shaft.. PICS INSIDE
Originally posted by 96ZRDR
Make sure yout steering shaft is not missing any of its bolts. It is bolted down with two. If you are missiong one, you will get play.
BTW the studd in that post above are exactly the symptons that I have so I know it is the rag joint...
I know that you can get a rag jint eliminator. Look here: http://www.unbalancedengineering.com/Camaro/
Scroll down and you will see it. That will eliminate the play and firm things up !
Originally posted by JordonMusser
LS1 will NOT work, (as stated above, off by 90)
just drill the rivets out of the rag joint, and replace them with bolts than you can tighten down.. no more play
thanks man
ro2207
Dec 4, 2014 06:18 PM
