LS1 vs LT1 Steering Shaft.. PICS INSIDE
Old Dec 16, 2003 | 05:00 AM
InjectedSS's Avatar
I wanna get rid of the POS steering shaft in my car since its already broken somehow and im getting play in the steering... Im wondering if the LT1 SHAFT is interchangeable with the LS1 SHAFT
Old Dec 16, 2003 | 08:17 AM
Stoopalini's Avatar
In this post Shawn states that the LS1 shaft will bolt right in to a LT1, but the steering wheel will be 90' off.
Thomas.
Old Dec 16, 2003 | 08:24 AM
96ZRDR's Avatar
Make sure yout steering shaft is not missing any of its bolts. It is bolted down with two. If you are missiong one, you will get play.
Old Dec 16, 2003 | 01:17 PM
InjectedSS's Avatar
no the play that im getting is in the stupid round center piece.. It has like rubber or some crap in there... You can tell it's that when I wiggle it around and the parts inside the center piece move before the actual shaft does so I know that it's that for sure...
BTW the studd in that post above are exactly the symptons that I have so I know it is the rag joint...
Old Dec 16, 2003 | 01:46 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
LS1 will NOT work, (as stated above, off by 90)
just drill the rivets out of the rag joint, and replace them with bolts than you can tighten down.. no more play
Old Dec 16, 2003 | 01:58 PM
95patriotZ's Avatar
I know that you can get a rag jint eliminator. Look here: http://www.unbalancedengineering.com/Camaro/
Scroll down and you will see it. That will eliminate the play and firm things up !
Old Dec 16, 2003 | 02:28 PM
InjectedSS's Avatar
If Jordan say's it won't work then "It won't work"
thanks man
ddr698
Jan 9, 2015 10:05 AM
ro2207
Dec 4, 2014 06:18 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
omarECD
Aug 19, 2002 07:28 AM
