LS1 swap
Old Dec 12, 2004 | 07:49 PM
NuMbNuTs670's Avatar
LS1 swap
Would I have to make any changes to make a LS1 fit into my 97Z28? Would it drop in pretty smoothly and would an aftermarket header and exhuast combo match up?
Old Dec 12, 2004 | 08:02 PM
cpt_bimes's Avatar
Re: LS1 swap
It should bolt right up to the motor mounts...
but i've read where you need a 98-99 LS1 because of some electrical hookups. LS1 radiator, fans, and prolly alot of other stuff that i forgot.
also, why the swap? did the LT1 crapout or did you get a good deal on an LS1 somewhere? Cause why spend 4-5k just to be as fast as every other Camaro/TA? Mod the hell out of that LT1 man.
Old Dec 12, 2004 | 08:05 PM
Dave89IROC's Avatar
Re: LS1 swap
mechaniclly, you need LS1 k member, LS1 trans, LS1 radiator, aftermarket hood
Old Dec 12, 2004 | 08:06 PM
cpt_bimes's Avatar
Re: LS1 swap
^^see i told you there was a whole lot of stuff that i forgot
Old Dec 12, 2004 | 08:34 PM
ChrisUlrich's Avatar
Re: LS1 swap
LS1 Trans? The Tranny won't bolt up to it? Isn't it a T56?
Old Dec 12, 2004 | 09:03 PM
cpt_bimes's Avatar
Re: LS1 swap
same tranny..diff. bellhousing
Old Dec 12, 2004 | 09:17 PM
turbo_Z's Avatar
Re: LS1 swap
Its a lot cheaper to mod your LT1 than it is to install an LS1 in place of it... and it will most likely be a lot faster too.
Old Dec 12, 2004 | 09:32 PM
Flmac02Z's Avatar
Re: LS1 swap
also I heard about something with the fuel lines or something...i forgot though...
~Kevin
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
surreybrad
May 31, 2015 10:37 PM
Zee man
Feb 12, 2015 07:07 AM
