LS1 Plastic Gas tank.
Originally posted by WS Sick
Its my understanding that the plastic tank is quite a bit lighter.
Re: LS1 Plastic Gas tank.
It appears a bolt in, but I'm still gathering parts. You have to use the stuff in the tank from the LS1 , but the fuel level sender from an LT1 car.
ws sick keep us posted on how the install goes. I have to pull my tank again anyways because I installed or damaged the floater arm. So I might as well put one of these in for the above reasons.
I wonder how much jason sells em for I'm going to call and find out. Did they use the same tank in 02 too?
I looked into doing this a while back, but never went through with it because I didn't want to be the guinea pig. Here's a couple of threads with some info.
http://web.camaross.com/forums/showt...light=ls1+tank
Originally Posted by shoebox
The plastic tanks are larger (16.8 gal as opposed to 15.5 for the metal tank). The plumbing with the LS1 pump is also different.
Thanks Shoebox for the info.
