LS1 lid and Fast Toys Ram Air
Old Aug 17, 2004 | 10:51 PM
  #16
lt4 fd's Avatar
Re: LS1 lid and Fast Toys Ram Air
Still curious if you noticed a gain over what you had right before it or if its the coolest setup?
Old Aug 17, 2004 | 10:54 PM
  #17
xxsaint69x's Avatar
its the best setup big SOTP difference esp at high speeds
Old Aug 17, 2004 | 10:57 PM
  #18
94 TA TT2S's Avatar
I will agree with that SOTP feel at High Speeds.....Part aren't too expensive either compared to the LT1 Raim Air setup.....
Old Aug 17, 2004 | 11:09 PM
  #19
kmook's Avatar
Advanced Tech Moderator
What did you do regarding the LS1 radiator shroud fitment?
Any plans on using a fernco instead of that ribbed duct?
Nice to see something new non the less.
Old Aug 17, 2004 | 11:13 PM
  #20
94 TA TT2S's Avatar
As from what I hear from the LS1 guys is that the fernco is for that every bit of power kinda guy....No real HP to be gained there.....
Old Aug 17, 2004 | 11:15 PM
  #21
94 TA TT2S's Avatar
Are you referring to the lower airbox???? Part that bolts to the core support....????
Old Aug 17, 2004 | 11:19 PM
  #22
kmook's Avatar
Yes, I had one and it seemed like it would need a lot of hacking to get it to fit on an lt1.
Old Aug 17, 2004 | 11:23 PM
  #23
94 TA TT2S's Avatar
Its not bad really ...Just better to know what to do before you do it...As I modded some places that didin't need it....lol....But really only thing I had to modd was were the extra bolt hole in the LS1 airbox was I had to trim it level with the outer one....Almost the whole Piece had to be removed....And if you are looking to get a good seal don't trim the airbox opening on the bottom edges....It will seal much better
Old Aug 18, 2004 | 08:40 AM
  #24
xxsaint69x's Avatar
CAN you take some pics of the modifications u had to do and the pic of the bottom of the hood?
Marcin
Old Aug 18, 2004 | 05:40 PM
  #25
94 TA TT2S's Avatar
I can.....Give me a day to get my camera ...its not pretty.....but effective....
Old Aug 18, 2004 | 05:56 PM
  #26
xxsaint69x's Avatar
already have a smooth bellow coming....for some reason the fernco was too short so i had to use the stock WS6 connector. As you can see i had to cut most of the LS1 air box on the sides as the hood wouldnt close.
Marcin
Old Aug 18, 2004 | 07:18 PM
  #27
94 TA TT2S's Avatar
Would yours not fit with out the stock Radiator support????? Or did you even try it like that????
Old Aug 18, 2004 | 08:40 PM
  #28
lt4 fd's Avatar
I have a suncoast creations ram air hood, basically a ws6 hood, what do you guys have... if it gives a big SOTP gain then that peaks my interest
Old Aug 18, 2004 | 08:48 PM
  #29
94 TA TT2S's Avatar
Harwood RA hood here
Old Aug 18, 2004 | 09:33 PM
  #30
lt4 fd's Avatar
What did you have to do to your hood and Box 94 TA TT2S to get the hood to shut?
