LS1 brakes on an LT1?
Old Sep 9, 2004 | 09:54 AM
Formula03's Avatar
I was told that you can put ls1 brakes on your lt1 car and get better brakes because the ls1's are two piston and the lt1's are on piston calipers. Is this true? Is there anything else that you would need from the ls1 car? Brakets lines anything like that?
Thanks in advance.
Old Sep 9, 2004 | 10:00 AM
GetaZforgetGT's Avatar
Re: LS1 brakes on an LT1?
http://web.camaross.com/forums/searc...earchid=115575
There should be a ton of info in that search...a lot of people have done this conversion.
Old Sep 9, 2004 | 10:33 AM
94YellowTAGT's Avatar
Stops much better. Of course that could be the hawk pads to. I use them and they work well for autox
Old Sep 9, 2004 | 12:27 PM
1msfyter's Avatar
Just be careful. When getting used brakes from auto dismantlers(ebay)A lot of them come bent and dont alighn right. I paid $189 for my complete set, but had to replace one knuckle. I also went with Irotors and Wagner thermo quiet pads. Made a huge differnce.
Old Sep 9, 2004 | 08:20 PM
Formula03's Avatar
So, other than calipers what all would I need?
Old Sep 9, 2004 | 08:58 PM
1msfyter's Avatar
Try to get the complete crossover set. Knuckles, calipers, rotors and brake lines. If you use the LS1 line you will need to bend the bracket that holds it(easy) Also before installing them clean them and throw on a coat of caliper paint and paint the knuckles.
Fparts or TNautoparts sell the complete set for around $180-200
Old Sep 10, 2004 | 08:09 AM
hawk232's Avatar
all you need is the spindles, calipers, rotors, and lines. i used wagners with my lt1 brakes and when i swapped i stuck with wagners, so as far i am concerned that should be pretty good for comparison purposes. DAY AND NIGHT difference between the lt1's and ls1's. it is to the point now were i dont like driving my girlfriends car (95 z28) because the brakes SUCK!!
Old Sep 10, 2004 | 10:15 AM
Formula03's Avatar
Thanks guys I appreciate it ill be doing the upgrade this winter.
Brake_L8
Jan 20, 2015 09:44 AM
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
vals95z
Mar 18, 2003 03:45 PM
