ls1 in a 93-97 z
Old Aug 30, 2004 | 05:31 AM
irishz28's Avatar
ls1 in a 93-97 z
has anyone ever heard of someone puttin a ls1 in a 93-97 camaro. the thought had been in my mind for awhile, im gunna be doin the engine in my camaro, when i get back from deployment and i was thinking of doing that switch, and putting my lt1 into a 87 monte SS. any thing out of the ordinary that i would need to know to acomplish this task. by out of the ordinary i mean, k-member, ecm, clutch, exhaust,and so on.if any one has any input please let me know.
Old Aug 30, 2004 | 07:46 AM
30696bird's Avatar
Re: ls1 in a 93-97 z
Do a search, it has been mentioned alot. Most say it's not worth it. ALOT of stuff has to be done.
Old Aug 30, 2004 | 07:55 AM
IslandZ's Avatar
For the money it will cost it isn't worth it. I have a wrecked LS1, but for the money it would cost to transplant it into my Z I would rather build a kickass LT1. Too many things need to be modified.
If you are set on the LS1 why don't you sell the LT1 and get the LS1!
Good luck!
Old Aug 30, 2004 | 11:05 AM
SS MPSTR's Avatar
Call Steve Cole at TTS - he did a lot of work for GM in the prototype fitment of the LS1 architecture into the 4th generation F-body. He had LS1's in Camaro's running around town before anybody knew what an LS1 was.
Old Aug 30, 2004 | 01:19 PM
z28marine's Avatar
for the money it would cost to put in a LS1 you could have a WAY better LT1... use the money to mod the LT1!
Besides have to put in a new engine, you have to get a different hood too... the 93-97 hoods will not fit with an LS1
Old Aug 30, 2004 | 01:22 PM
SS MPSTR's Avatar
Who told you that?
Old Aug 30, 2004 | 06:29 PM
pearlpurple's Avatar
I don't remember where I heard this but I too have heard this. In fact I also heard that is one of the reasons for the front end change from 98 to 99.
I sure would like to know if this is accurate info or not.
Old Aug 30, 2004 | 06:34 PM
turbo_Z's Avatar
You can overpower and outrun an LS1 with just a cam swap in the LT1... much cheaper and less time consuming.
Old Aug 30, 2004 | 11:03 PM
shrek127's Avatar
If the LS1 is stock a cam swap in a LT1 the LT1 will drag it. But most LS1 guys aren't stock, my roomates LS1 puts down 422 at the wheels. I know a cam LT1 will not hang with his LS1 and he has stock heads and no Nitous.......Yet.
Old Aug 31, 2004 | 02:23 AM
stik6shift93's Avatar
Full bolt on ls1s can make 360 to the wheels which is more than most cam only lt1s. A better choice would be to get a good set of sbc heads(which can outflow ls1 heads by a nice margine) and have them converted to reverse flow cooling. Then by a carb intake and convert it to a regular style distibutor. The downside is that you'll need cowl hood or high rise ram air hood but it'll be cheaper and have a lot more potential. Also you'll need a ls1 transmission to do a ls1 swap as they aren't interchangable.
Old Aug 31, 2004 | 05:04 AM
irishz28's Avatar
ok the ls1 idea is now out, it was just an idea i was tossing around, im just undecided as to what direction i want to take naturally aspirated or forced air, super charger or turbo would be cool but i have a feeling that i will get more bang for the buck going naturally aspirated. i should have quite a bit of money to play with when i get back.
Old Aug 31, 2004 | 09:59 AM
kevm14's Avatar
Don't LS1s also use a different steering rack? Someone told me this recently.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
alliance12364
Sep 17, 2015 08:43 AM
