LPE heads and Joe Overton cam track times inside...
Originally posted by TCAL95Z
Nice times.
You need slicks.
Did you get any kind of flow numbers on those heads?
I just got a solid roller cam from Joe and had his friend Eric port my LT4 heads and intake. The LT4 heads had a Lingenfelter CNC job allready done to them and they only flowed ok. Eric wasn't to impressed with them and they look a lot different now.
I can't wait to get the 383 in the car. Looks like Joe has done several cams lately there should be some nice numbers coming out soon.
Nice times.
You need slicks.
What did your heads flow.....
Originally posted by LPE Z convt
Has anyone cut good sixty foot times on nittos ... Mine are 17 inch and just don't seem to hook like they should......
Originally posted by ZPaul2Fresh8
BFG's are softer, they work great for me.
My heads flowed almost exactly the same. I had them flowed by a local shop. Are those the numbers LE gave you? Or did you have them flowed by someone else?
Eric was able to pick up 21cfm on my heads and he said the ports did not flow consistent. He flowed them first to see what they did on his bench and then he ported one to see how much he could gain. I think thats about the only way you can do it since flow benches don't give the same numbers. The heads look a lot different now. Eric semed to think that it would run very well. When he received them his comment was --they need a lot of work. I had him do the LT4 intake too.
I think you have a cool combinaton and a good goal.
I want to run high tens NA
Those #s were from LPE.. I asked Joe when he was designing my cam if he wanted me to pull the heads and have them flowed and he said not to.... I may now if you gained 21cfm and go solid roller but the heads and cam may find their way over to the 97 SS i bought 3 weeks ago
Their is a big diffrence in weight between the two cars...If Eric does my heads i will put the convertible back to stock and build a stought bottom end for the SS to handle at least 200 shot of nitrous.... But i need to see what the vert will do on the spray first....Hey if you remember send me an email when you go to the track or get dyno #s and i feel 10s should be no problem for you N/A... Lingenz@insightbb.com is my address...
Thanks Chris
Their is a big diffrence in weight between the two cars...If Eric does my heads i will put the convertible back to stock and build a stought bottom end for the SS to handle at least 200 shot of nitrous.... But i need to see what the vert will do on the spray first....Hey if you remember send me an email when you go to the track or get dyno #s and i feel 10s should be no problem for you N/A... Lingenz@insightbb.com is my address...Thanks Chris
oldschool
Feb 9, 2016 09:21 PM
teedoff59
Aug 8, 2002 01:36 AM
