code P1626, need help
Old May 12, 2004 | 01:27 PM
96HealyZ28's Avatar
I was cruisin down the street yesterday and decided I should stop for gas. Filled up, then when to turn the key and.......... nothing, all lights and accessories worked so I knew it wasn't my battery. Gave it a few more tries, checked my gas cap to make sure it was on tight and still nothing. I had it towed to my brothers shop where we ran the codes and I got P1626 Theft Deterrent Fuel Enable Signal Lost. I thought just maybe it was my key, because the pellet is a little loose so I went and got a new key made at a Chevy Dealorship. Still nothing. We checked to body control module for the theft detterent system and all wires and harnesses were looking good. Any ideas what the hell is wrong with my car? I got it at the shop right now but they havn't looked at it yet so I figure if I get some ideas about what can be wrong I can save some money by pointing them in the right direction. Thanks in advance.
Old May 12, 2004 | 02:29 PM
Probably the first thing needed to be known is "what is the SECURITY lamp on the dash doing?". When the key is turned to ON, it should illuminate for 5 seconds or so and then go OFF. If lucky, maybe you just have a loose connection at the BCM.
Old May 12, 2004 | 03:14 PM
96HealyZ28's Avatar
The security light is flashing when I turn the key, which in the book says I might have a damaged resistor in my key but I got a new one and it still didn't work so it wasn't that. Thanks shoebox.
Old May 12, 2004 | 04:47 PM
But the problem may still be that it cannot read the key. Since it seems it is not the key, itself, the key cylinder would be suspect. You can bypass the reading of the key by putting a matching resistor at the VATS plug under the dash . You can also unplug that connector and see if you can read the key back through the wiring to the key cylinder. Maybe that will point you in a good direction. Key values.
Old May 14, 2004 | 04:10 PM
96HealyZ28's Avatar
Thanks for the info shoebox, Im gonna replace the key cylinder. I did a search and somebody else that had the same problem replaced the cylinder and the problem was resolved.... Too bad I had already made a new key for the other cylinder =( but we live and learn. Thanks again shoebox.
Old May 28, 2004 | 06:57 PM
Brundle's Avatar
I"m having the same problem. Did changing the cylinder solve the problem??
Old May 31, 2004 | 01:44 PM
96HealyZ28's Avatar
Yes, changing the cylinder did fix the problem
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
