Lowering the Z
Old May 8, 2003 | 02:27 PM
Bascue/z's Avatar
Lowering the Z
Whats the best kit to do this with? How long is it taking you guys
PS How is the ride (rufer or smother)? Also do we have struts on the front?
Old May 8, 2003 | 02:31 PM
Camaro_Guru16NY's Avatar
In my opinion the eibach pro kit is the best if you have long tubes you can go one more step lower to the sportline kit which is an extremely low drop. I looks cool but agin if you header work or a body kit then watching where you drive will become a problem.
Good Luck to'ya,
-JOhn
Old May 8, 2003 | 02:56 PM
Bascue/z's Avatar
How long did it take you?
PS What about the struts in the front?
Old May 8, 2003 | 03:18 PM
The back is easy-about an hour-hour and a half if changing shocks and springs. The front shocks are more involved and you will need a spring compressor or take them to have the springs swapped. About 3-4 hours for the front, depending on your skills and problems you encounter.
Your ride will not be smoother, but stiffer.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
