Low Water Light....!!!!
Old Feb 22, 2004 | 10:12 PM
Heatmaker's Avatar
Advanced Member
WTF is it f34k me day or somehting....
My water light came on.... I've only had my CSI in there for a couple of months...still activating working so it can't be that...so what would cause the low water light to come on? This is sucko! Big time-o! I'm guessing my Temp sensor is F34ked on my water pump and is causing my car to run hotter....lametacular! ...need a new sTemp sensor...where's the best place to find one? atleast this fix doesn't involve pulling the tranny again....this blows!!!
Old Feb 22, 2004 | 10:17 PM
sabre81's Avatar
i hear you can just unplug the sensor so that you dont see the light. I think the plug is somewhere around the radiator filler neck. Myabe someone else can confirm this.
Old Feb 22, 2004 | 10:33 PM
LanceJoker's Avatar
That happens to every LT1 sooner or later.Most people unplug the light in the dash.As long as you know there is coolant in it and its not overheating,don't worry about it.
Also,I unplugged mine once and for some reason the car wouldn't start afterward.Weird.
Old Feb 22, 2004 | 10:41 PM
Robs97Z28's Avatar
My light started coming on after I put on new cap. When back with the OEM cap from the dealer. The damn thing went out. Then, 2 months later the light was back on. It took me two weeks to figrue out the water pump was taking a crap. It wasn't losing any coolant but the seal would draw in air as the engine cooled down. Instead of pulling the coolant back into the rad from the over flow bottle.
Old Feb 22, 2004 | 10:43 PM
1msfyter's Avatar
Mine came on when the temp went down to 39* plus I replaced
my cap and that solved the problem.
Old Feb 23, 2004 | 12:06 AM
RED82TA5.7L's Avatar
when i first bought my 96. the low coolant light would come on. brang it to dealer(where i bought it) they replaced the sensor and fixed it, and now 6 months later still no light
um. if its running hotter, have you checked the coolant level?
Old Feb 23, 2004 | 10:58 AM
Heatmaker's Avatar
Advanced Member
dang Chevrolet
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
pologreen97z
Dec 2, 2014 10:42 AM
