Low Voltage...
Old Jul 23, 2009 | 10:18 AM
  #16
raroz28's Avatar
Originally Posted by shoebox
When you pull the armature out, the brushes may pop out, because they are spring loaded. The holders should stay in place, though. When you re-assemble, there is normally a way to push the brushes back in and "pin" them from the outside, so you can insert the armature. You then remove the pins to release the brushes. Usually a paper clip or small nail can be used as a pin.
Yes, you put the springs in, then the brushes, hold them in with the pin, then once the alternator is assembled, you pull the pin from outside the alternator and you will hear the brushes snap into place.
I'm just surprised to see this piece snapped the way that it did. I wonder if that was from dropping the power wire.
Old Jul 24, 2009 | 09:54 AM
  #17
raroz28's Avatar
btw, I replaced the brush holder last night and it's like new again.
Couldn't believe a reman'd alt is 175 bucks. An alternator for my Conquest was like $45. Kinda crappy since the most expensive part inside the alternator is like 30 bucks. Lucky for me, this part was only $18.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
