Low Stumble solution (for me)
Old Sep 21, 2003 | 07:19 PM
zslates's Avatar
Typical, after it gets warm (10-15 min) it stumbles. So I replaced the spark plugs and the wires. It seemed to be fixed but wasn't. The spark plugs I put in were NKG Tr55. I was sure it was the opti, but I decided to change the gap on the spark plugs to .35 instead of .50. So I pulled the plugs out and they were gapped at .58! So now that I've gapped them to .35 there is no more stumble. I let it idle in 95 degree heat for 10 minutes, and then I took it for a 20 minute test drive. NO STUMBLE. I thought I would post this for all you guys out there. I know how frustrating it is.
Hope this helps someone,
Zack S.
PS I also replaced the coil and mounted it away from the block, replaced EGR valve.
Old Sep 21, 2003 | 07:39 PM
snakeatinZ's Avatar
god bless you!!! I will try this!
I am battling a stumble problem myself
Old Sep 21, 2003 | 09:45 PM
zslates's Avatar
Hey no problem. The reason I had the hesitation the first time was because my #7 plug wire was melted, and the platinum tips had fallen off the spark plugs. I just took it for another test drive this time like a 30 minute one, free way driving, in town and it did great! Hope this saves someone from buying an Opti! My Opti has 110k miles on it to!
Zack
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
speedracer1280
Sep 8, 2015 06:12 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
