low rpm stumble eh?
Old Aug 16, 2004 | 07:17 PM
Trmpt63529's Avatar
low rpm stumble eh?
i've searched and searched and can find no answer. stumbles until 2500 rpms then runs like a champ. does it in open and closed loop. and gets a hair worse with a higher temp. i've changed the tps, iat, plugs, maf , map, and both temp sensors. tested the knock sensor. i've changed all of these off of a 95 z to a 94z, none made any difference. i figure since it does it in both loops that it's not the 02's. i've got a msd blaster coil and wires, and i don't think that its them.. because it does it even when its not under a load. but at the same time it's not a miss. if you have any idea's i'm all ears... thanks! Mike
Old Aug 16, 2004 | 10:02 PM
Trmpt63529's Avatar
Re: low rpm stumble eh?
any help? this is driving me insane!!!
Old Aug 16, 2004 | 10:10 PM
Myxtreme1's Avatar
pcv valve and grommet? fuel filter. Changed mine the otherday bacause I was noticing a good bt of hesitation and only after 8000 miles my filter was bad gunked up. It made a difference. I am going to also get a gm parts pcv filter and grommet just for good luck as well.
Old Aug 29, 2004 | 11:17 AM
95WhiteTA's Avatar
What does it feel like when it stumbles? Does is vibrate at all?
Navecm
Jun 1, 2015 05:57 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
