Low RPM Miss Stumble (could someone look at the datalog)
Old Apr 5, 2007 | 09:14 PM
xstoyz's Avatar
I have been having some issues with a miss/stumble. There have been no codes from this issue. The Miss/Stumble happenes below 2500rpm and is noticable when there is load on the engine. The datalog shows a short trip around the neighborhood with 2 very short highway runs. I included both the .csv file (excel) and the .atl file (autotap). Any help would me greatly appreciated.
http://www.mediafire.com/?0k02jyh4hnn (Autotap)
http://www.mediafire.com/?9jytd0jbjtd (Excel)
Old Apr 5, 2007 | 09:21 PM
79prix's Avatar
have you tried having the car run and spraying carb cleaner and seeing if rpms change may be a vacuum leak
Old Apr 5, 2007 | 09:23 PM
79prix's Avatar
just thought of another thing buddy needs to replace E.S.C for same issue a tech told him sometimes it won't trigger the check engine light
Old Apr 5, 2007 | 09:32 PM
xstoyz's Avatar
I will try the carb cleaner tomorrow. Good idea.
ok you stumped me what is E.S.C?
Old Apr 6, 2007 | 10:48 AM
xstoyz's Avatar
Ttt
Old Apr 6, 2007 | 11:20 AM
79prix's Avatar
Electronic Spark Control there are 8 differnt kinds maid for these year cars need to find were its located could be in a # of places then bring it to a part store and based off the manufacturer # they can get you the correct one
Old Apr 6, 2007 | 06:32 PM
79prix's Avatar
if carb cleaner didnt do anything spray water on plug wires and see if you get a miss a good mist should do the trick
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
