Low Res
Old Jun 6, 2005 | 08:52 PM
c0rey's Avatar
Low Res
Is there a way to replace just the low res on the opti? This is like my 5th opti and dont want to buy another one.
Old Jun 7, 2005 | 05:09 AM
slopokrodrigez's Avatar
Re: Low Res
Why don't you find out what's killing it and fix the cause instead of the symptom?
Old Jun 7, 2005 | 10:43 PM
c0rey's Avatar
Re: Low Res
What part went bad just the module inside or what? I can get a new module for cheap I have another module sitting here from a opti that the rotor flung off of?
Old Jun 8, 2005 | 04:53 PM
c0rey's Avatar
Re: Low Res
Does anyone know the website for the optispark that shows the detailed pics of the opti getting torn down?
Old Jun 23, 2005 | 10:23 PM
c0rey's Avatar
Re: Low Res
Had a buddy check the low res and high res part out and he said they were working, so is it the cap and rotor??
Old Jun 23, 2005 | 10:48 PM
omatter67's Avatar
Re: Low Res
shoebox.com
Has a diagram of the opti and all the internals. I'm also getting low res on mine but I also haven't finished my plugs and wires yet so we'll see after there done. I'll let you know how that pans out.
Old Jun 24, 2005 | 01:23 PM
cas0484's Avatar
Re: Low Res
Sounds like your cap and rotor went out. You might want to look into the Delteq/LTCC systems. It might save you some money and time in the future.
Old Jun 24, 2005 | 01:33 PM
Re: Low Res
I think it would be a smart idea to spend some time finding what's causing the problem, rather than keep replacing parts. Lacking any info on the year of your car, and no other info than its blown..... do you have a vented Opti and how is the vent system hooked up, to avoid overpressuring the Opti with the boost?
Old Jun 24, 2005 | 04:54 PM
c0rey's Avatar
Re: Low Res
Its vented now the boost is gone as well. I think moisture was the killer.
Old Jul 4, 2005 | 05:05 PM
c0rey's Avatar
Re: Low Res
Well I seen that the cause could have been low battery charge in the battery. I was starting the car with the alt off to adjust the rockers. I have a new harness. Going to check all the connections and charge the battery completly and hook the opti up and see what comes out of it. The guys said the low res and high res was fine he tested it with a olethascope(sp). If nothing i try works i guess its time to buy a new cap and rotor.
Old Jul 5, 2005 | 05:35 AM
Re: Low Res
How can anyone help you if you don't give us the symptoms of the problem. You've already proved the feedback portion works. Why do you keep thinking the opti is bad?????
And how does a low battery effect it if someone has already said it was good?
Old Jul 5, 2005 | 06:03 AM
c0rey's Avatar
Re: Low Res
The car was running perfect then all of the sudden go to start it again and bam hard start and the whole engine ideling beyond cam rough, no power, and the low res code.
Old Jul 5, 2005 | 06:19 AM
MyTMous's Avatar
Re: Low Res
I had this on 3 "new" opti's I put in, they would only go bad ie. throw a
high or low res code, after they heated up.
4th one was a charm, running 1+ year on it with no problems.
2nd one cost me the most, as it heated up on the first test drive,
threw what I found was both a high and low res code, and the engine
died, while I was going around a corner, long short, I crashed into the
curb and busted both wheels on the pass. side.
just cause it test good doens't mean it's good all the time.
most opti issues happed when they get hot.
Old Jul 5, 2005 | 08:08 AM
Re: Low Res
I notice you changed your signature NOW to remove the blower. Do you have any idea how frustrating it is to people to find out they tried to help someone, and essentially wasted their time because the information provided in the initial post was incorrect. It's extremely inconsiderate.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
