low power after opti install
Old Jun 16, 2008 | 03:36 AM
BIG_T's Avatar
well after taking the car apart for the 2nd time bc the damn opti got splined wrong and then my crank bolt threads got jacked up i finally got the car back together with the help of a few buddies. however, on the first test drive (cold) the car studdered under a load (more than 1/2 throttle) then when it got warm the car runs smooth but has low low low power levels. the opti was installed right im 100% sure and the firing order is right. im getting everything i need fuel, spark ect. the plugs are brand new and looked good when i pulled one after the test drives. anyone have any ideas? thanks
Old Jun 16, 2008 | 05:05 AM
What else did you do beside the Opti? How did the crank bolt threads get screwed up? You must have been doing something besides the Opti.
Old Jun 17, 2008 | 08:22 AM
BIG_T's Avatar
nope, just doing the opti and a buddy messed the crank threads up when we were puttin it on tdc. i fixed that with a helicoil though so no biggie. any input guys. im testing my fuel pressure tomorrow
Old Jun 18, 2008 | 08:33 PM
oneqwkfbody's Avatar
dude,,,going thru the same thing...sounds like. im pretty much at the point you are...im going after my o2 sensors next...and if that dont do it...then my Ignition module and / or coil. check out my other threads if you havent alrady....seems a bunch of people are having trouble after or with their optis//// if you find a solution please post it!
good luck
Old Jun 19, 2008 | 05:45 AM
BIG_T's Avatar
good luck
i founf my problem even though all my wires looked good i pulled them all off to examine and found that 4 hard burnt a lil (only 3k old lol) put new msd wires on and it runs like a champ again. are u throwing any codes?
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
