Low oil pressure when engine warmed up
Old Jun 1, 2005 | 05:37 PM
Sypher's Avatar
The oil pressure is fine when i start it up around, 20 psi at idle. After about 20 mins of driving the oil pressure drops down to 10psi at idle. What do you guys think is causing this? pump, bearings?
Old Jun 1, 2005 | 05:46 PM
atljar's Avatar
Re: Low oil pressure when engine warmed up
Likely the motor is getting some miles on it and the bearings are wearing.
What oil weight are you using?
Old Jun 1, 2005 | 05:54 PM
Sypher's Avatar
mobil 0w40
Old Jun 1, 2005 | 06:08 PM
atljar's Avatar
Well before I would be concerned, I would put a mechanical gauge on the car and make sure the gauge on the dash is correct. Sometimes the senders fail.
Technically speaking, by GM specs that is an Ok oil pressure (10 psi), but really on the low side of things. You could try going to mobile 15w-50 and see how that does, but its just a cover up more or less for a tired motor.
HectorM52
Jul 30, 2017 11:46 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Injuneer
Dec 15, 2014 09:36 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
