Is this low for oil pressure? help please!
Old Mar 27, 2005 | 03:47 PM
  #16
CJ Black LS1 Z28 M6's Avatar
Re: Is this low for oil pressure? help please!
Well i drove the Z again last night after the car was totally warmed up the needle stayed slightly above the 1/4 mark when crusing about 1500 rpms and when stopped at a light just a hair above the red mark what do you guys think?
Old Mar 27, 2005 | 06:12 PM
  #17
blaze309's Avatar
Originally Posted by 94zgreenmachine
From GM service manual:
These are minimum oil pressures
6 psi @ 1k RPM
18 psi @2K RPM
24 psi @4K RPM
Low isn't it!
WOW that is low, mine at idle is around 20-22 so i feel good about my engine now.
Old Mar 27, 2005 | 08:35 PM
  #18
SlowAssTA's Avatar
mine at idle is about 38, and 70 - 75 at WOT once warm...
Old Mar 27, 2005 | 08:43 PM
  #19
groverk's Avatar
Put a manual gauge on it and see if the problem is in the gauge or in the bottom end. It`s easier to fix a lower end problem now and not wait till the motor grenades.
Old Mar 27, 2005 | 09:37 PM
  #20
munkyZ28's Avatar
has anyone ever used the lucas oil stabalizer with their mobil 1 syn. oil to raise up the oil pressure? it helped out alot on my 87 camaro but havent tried it on my 93 z or with synthetic oils.
Old Mar 27, 2005 | 09:53 PM
  #21
izzyz28's Avatar
I switched from M1 10W-30 to 0W-40 a few months ago and it works great! Oil pressure at hot idle is ~30 PSI, 45-50 PSI at cruise, and ~60 PSI at WOT. I ran this oil most of the winter, and didn't notice any lifter clatter like I did with the 10W and 5W-30 M1 I was running. It seems like a very good oil and I'm going to stick with it. BTW, when the 30WT oils were hot I would notice a slight drop in pressure, but not with the 0W-40.
Old Mar 27, 2005 | 09:56 PM
  #22
NewbieWar's Avatar
yea thats about where mine is, maybe lower at high rpm... but its about that... at start up its good
but both my oil pans tranny and engine have huge dents in them... i donno if that has anything to do with it...
it helps to use straight 50 for me but thats in warm cali
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
