Low oil pressure?
Old Jul 1, 2008 | 11:28 AM
chris8835's Avatar
Low oil pressure?
Is this oil pressure normal for an LT1 at idle? It seems so low to me. I just want to make sure this is nothing to be concerned about, or is it?
Old Jul 1, 2008 | 11:40 AM
EnFuegoZ28's Avatar
Stock oil pressure is 6psi @ 1k rpm's. Yours looks like your oil pressure is fine.
Old Jul 1, 2008 | 12:30 PM
seawolf06's Avatar
Search here for the stock oil cooler and decide if it's worth your time to change it or not.
Old Jul 1, 2008 | 08:00 PM
CheshireCat's Avatar
Your oil pressure looks exactly like mine. Very normal at hot idle...
Edit: Just noticed that you're at 1k RPM... Mine idles at around 650 RPM... My pressure is higher at 1k RPM..
Old Jul 1, 2008 | 09:31 PM
Pontiac_97's Avatar
its a tad low. nothing bad. as long as it shoots up to around 40 when you hit the gas your fine how many miles on the car?
Old Jul 1, 2008 | 10:13 PM
chris8835's Avatar
Hey guys,
Thanks for the info, I was just wondering what the oil cooler would have to do with the pressure being low? I guess i'm kinda getting mixed answers here so I think I will just take my chances and not worry about it for now. It has been like this since I bought the car with 24,000 miles, it now has 64,500 on it right now. So if something was to go wrong I guess it would have done so by now. I have never had any problems with the engine what so ever, and I have had many track passes along with many, many street runs.Lets just put it this way I have put the car through hell and back with no problems at all.Also yes the gauge does shoot up to 40 at normal cruising speeds. So I guess it's nothing to be to concerned about, considering I have heard from most people that it is normal.
Old Jul 2, 2008 | 05:54 AM
The oil cooler is notorious for getting clogged and being restrictive. That being said, since you have an automatic, I'm not sure that you have one... I may be wrong, but for some reason I think they only put them on the manual transmission cars...
I wouldn't worry about your oil pressure. If you are worried, you can get a pressure gauge and verify that your dash gauge is giving you the correct indication.
Your pressure doesn't look that low. The "rule of thumb" for a SBC is 5psi per 1krpm...
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
