low oil pressure
Old Dec 3, 2007 | 11:34 PM
  #16
SS RRR's Avatar
Originally Posted by Terran2k
well I replaced the sensor, the old one was broken, the plastic seperated from the metal, but it didn't matter, its doing the same thing with the new sensor. I started it up and oil pressure was ~55psi, then warmed up and was just over 20psi, but when I started to drive, it started to lose pressure; while moving it had 20-25psi. but when I stopped at a stop light it read almost 0psi. What do you guys think?
I would still put an analoge gauge on it just for finality reasons. However it looks like you either drive it until it ceases which will cost you even more money or you tear it down for some exploritory surgery to see what the cause was. Most likely you have a wiped bearing(s).
Old Dec 4, 2007 | 09:20 AM
  #17
01Z's Avatar
01Z
Well, that's disappointing but now you might want to hook up a mechanical pressure gauge to verify the reading is correct; although I suspect that it is.
Although people think things like spun rod bearings with low oil pressure, the common cause of low pressure is worn cam bearings. If it were me, I would consider trying a 10w40 oil just to see if that bottom pressure improves. If it does, then you can live with thicker oil for a while or think about another motor, a rebuild or just drive it as it is. According to GM, the service limit is 6 lbs at idle - that's your red area.
I could be wrong about what to do so check with others before spending a lot of money. Maybe it's the pump but I doubt it with the 55 lbs at start up.
Old Dec 4, 2007 | 12:00 PM
  #18
J's 82's Avatar
Your symptoms sound exactly like mine when I had a spun cam bearing.. Warm idle was as close to zero as you could get, rev it up it would get to 25 or so.. torn apart one of the cam bearings had moved in its journal and looked pretty darn ugly.
Before you go putting thicker oil in it make sure you don't have a bunch of small metal filings in your oil filter..
Old Dec 4, 2007 | 03:13 PM
  #19
Terran2k's Avatar
I drained the oil and it didnt have any metal, but I dont plan on driving it anymore
Old Dec 5, 2007 | 08:44 AM
  #20
regal502's Avatar
LT1 Oil Pressure
I remember reading some GM documents not to long ago. Most would be surprised what GM mandated for oil pressure. I don't recall the specs exactly, but at idle (800rpm) it was like 9psi. I don't remember the middle spec, but the high end spec (@ 4,000 rpm) it was only like 40psi.
It should be a comforting thought that you don't need excessive oil pressure in any motor. Remember, NASCAR motors run at 8,000+ rpm for 500 miles with only 45psi!!
Old Mar 18, 2008 | 12:02 AM
  #21
Oxygen454's Avatar
Quick question, on the oil sending unit, is there any special tools required to remove it? I think this may solve all my problems.
Old Mar 18, 2008 | 04:55 AM
  #22
Kaj's Avatar
Kaj
nothing good, sounds like a spun bearing...
Old Mar 18, 2008 | 06:53 AM
  #23
As already previously noted, you need a special oil pressure sensor socket (available at auto parts stores).
Old Mar 18, 2008 | 06:02 PM
  #24
Oxygen454's Avatar
OKay thanks for the info shoebox. I must have miss read that somewhere
Old Mar 18, 2008 | 08:33 PM
  #25
Oxygen454's Avatar
Just for those looking, found a few here...
Socket
Oxy
Old Mar 18, 2008 | 08:57 PM
  #26
Oxygen454's Avatar
GM quoted me not long ago approx 10 psi.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
