Low octane gas=backfire?
Old May 16, 2004 | 11:48 AM
TLyden316's Avatar
Question Low octane gas=backfire?
I have been getting backfire in high rpms, right before the engine shifts. This started around the time I started using midgrade gas instead of premium, because of the price. Is this just a coincidence, or could it be because of the gas? Last summer I changed my plugs and wires, but not the coil. I'm not sure if the problem is as simple as the gas or if it's ignition related. Thanks.
Old May 16, 2004 | 12:16 PM
LT1Squirrel's Avatar
switch back to premium for about 2 tanks and see if it remedies the problem...low octane + summer could mean detonation
Old May 16, 2004 | 04:27 PM
madwolf's Avatar
Yep, sounds like it. Try some premium first. If there's no detonation and you want to continue running lower octane gas, I'd recommend pulling out some timing from the programming because it's pretty aggressive for mid grade.
Chet1185
May 10, 2015 09:24 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
DarkHorse
Aug 3, 2002 10:17 PM
