Low idle after comming to a stop
Old May 10, 2005 | 06:48 PM
Valkyn71's Avatar
finally got my car out on the road again from storage and its acting strange, just like before i put it in.
When I come to a stop and let out on the gas and push in the clutch, my RPMs drop down to around 500-600, car kinda of sputters and acts like its going to stall but then revs back up to around 1000 and idles fine.
Anyone know why it does this? Is it a tuning issue?
Is pretty annoying, im always sure its going to die.
Anyone who can shed some light would be much appreciated.
Old May 10, 2005 | 09:52 PM
Zjoker's Avatar
Re: Low idle after comming to a stop
Check IAC for gunk or EGR for damaged diaphram.
Old Jul 18, 2005 | 04:38 PM
jchevy's Avatar
Did you ever figure this out?
Old Jul 18, 2005 | 05:17 PM
matLT1's Avatar
I'm not too sure that I'd call that a low idle myself. My car idles fine at 550 rpm in gear. But like Zjoker said I would check the IAC. If you have a repair manual it will tell you how to test it.
Old Jul 18, 2005 | 05:32 PM
Valkyn71's Avatar
It seems to have stopped doing it, but if you saw my comp R lifter problems thread you know i have bigger fish to fry than this now
Old Jul 18, 2005 | 05:34 PM
jchevy's Avatar
Im having the same problem and i cant figure it out.
Good luck with your lifters.
Old Jul 18, 2005 | 07:22 PM
Mystic97Z's Avatar
mine does the EXACT same thing...notice we are all head/cammd cars.
it really sucks because if i turn my wheel while coming to a stop it will drop to really low oil pressure. so i gotta brake with my left foot and give her throttle with my right...while its in nuetral (6 speed)
Old Jul 18, 2005 | 07:29 PM
sw89lt1's Avatar
i've got the same problem with mine after the install. who did your tune?
Old Jul 18, 2005 | 07:45 PM
jchevy's Avatar
Yeah, i know what you mean about turning, like to pull into a parking spot. Mine will actually completely stall sometimes.
A friend of mines h/c car has the same issues...
Ive been searching for the last hour or so. One thing I am going to check is the EGR valve, i guess that could be a possible culprit.
Next step would be to drill out the IAC hole a little bit to see if it helps.
Its strange though, mine wont do it all the time. Sometimes it will run fine.
Old Jul 18, 2005 | 07:47 PM
sw89lt1's Avatar
i deleted the egr system on mine. so i know thats not the problem. good luck
Old Jul 18, 2005 | 09:46 PM
ZMAN Z28's Avatar
Pull the valve covers and see if you have a cracked or broken spring. My car was missing, but acting very similar with the idle and oil pressure. I had a broken valve spring. Not sure if it fixed it yet as I pulled the motor to see if there was any more damage. There wasn't, but it got rebuilt.
ZMAN
Old Jul 18, 2005 | 09:49 PM
jchevy's Avatar
I know for a fact i dont have any broken valve springs.
When i get home in about an hour im gunna pull the TB and drill out the IAC hole a little bit bigger. Ill let you guys know how it goes.
Old Jul 19, 2005 | 12:43 AM
jchevy's Avatar
When I took the TB off and then pulled the IAC out i noticed that the gasket for the lower coolant plate was wrinkled and half blocking the IAC passage. I replaced the gasket and no more idle problem! So it appears i found the cure for my problem.
Now onto the next one of passing emission next month.
Old Jul 19, 2005 | 01:25 AM
FlyboyZ28's Avatar
I have this problem as well. Its only in the mornings or when i first start my car after its been sitting for a while. It'll idle low and then come back up. As soon as I put it in gear it will idle down slowly then die. I have a coil that leaks a lot of spark. I replaced my msd coil with a used stock one and still does the same thing. Does anyone think this could be the problem?
Old Jul 19, 2005 | 02:17 AM
blwnlt4's Avatar
That sounds like an IAC problem to me but there are many other possibilities
