Low ET's and Trap speeds from cc503
Old Aug 1, 2007 | 09:57 PM
TransAm-Z's Avatar
My best run with all the mods listed below was
12.67 1/4 mile @ 106.9 mph
1.779 60 ft
It seems that everyone else running similar setups are running between 110-120 mph and better times. I have about 100K miles on the stock 4L60E tranny and it is bouncing off the rev limiter when it shifts from 1st to 2nd. Also I noticed the o2 sensor were reading around 850's - 940's. Could the low times be due to the transmission slipping or am I possible running too rich?
I have reajusted the lifter to zero preload to see if I gain anything (Will know tomorrow)
Old Aug 2, 2007 | 04:12 AM
<Puck>'s Avatar
1.779 60 ft
Your mph is way off, most likely due to the tranny slipping.
Old Aug 2, 2007 | 10:20 AM
JoeliusZ28's Avatar
12.6 is not a bad time for that cam, but you should be trapping a little higher. i would also point the finger at the trans.
edit: just noticed you have heads. nevermind, you should be about a flat 12 IMO.
Old Aug 2, 2007 | 11:32 AM
urbaNHunter44's Avatar
I'd expect a much higher trap, something is definetly wrong. The tranny slipping definetly doesn't help but you should still be much higher (I'd expect at least 115 at sea level). Those bolt-on times you're running.
What are you doing for a tune? You have a dynotune for all those mods I hope? A tune will make or break you.
What springs? What's the lash on the rockers?
ZZed
Sep 10, 2002 04:13 PM
z28kid93
Aug 22, 2002 04:40 PM
Notford95
Aug 20, 2002 01:46 AM
96z
Aug 2, 2002 09:00 PM
TrouserSnake
Jul 19, 2002 07:47 AM
