Low end question for High end people
Old May 19, 2003 | 12:13 AM
5H9D0W's Avatar
I installed a vigilante 3200 and a trans-go shift kit today.I took it out and locked the converter up a bunch of times to break it in,so after I broke it in I hit it from a stop.It went to about 3500 instantly and shifted to second,meanwhile my tires won't hook up.At second it went to about 4500 and dropped to 3500 and went back up again.In third it just about did the same thing.Meanwhile,my car still won't hook up.So I made 3 street passes and the same thing happend every time.Where are the hard shifts I was waiting for,it's less potent then before I put the trans-go in.I went ahead and put 3 spacers in the accumulator body to get the hard shift.What does this sound like to you.I know I put everything in right.Any advice would be great. Mike
Old May 19, 2003 | 05:58 AM
You are going to find a lot more people on LT1 Tech with your combo than you are here. Moving to LT1 Tech to help you get an answer.......
Hurin
Dec 13, 2014 07:38 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
ezcheeze15
Aug 26, 2002 01:28 PM
squirrels
Jul 13, 2002 01:58 AM
