Low dyno numbers. Any ideas??
Old Jan 13, 2006 | 04:02 AM
cmking26's Avatar
I thought 333rwhp and 326rwtq was pretty low for cc306. It was a brand new spec 1, heads are stock with bull blend, fresh rebuild, and car quit making power at 62-6300. Any ideas why so low on power? I've seen stock heads and 306 make 350hp. Was a dynojet.
Old Jan 13, 2006 | 04:23 AM
BlackbirdWS6's Avatar
Re: Low dyno numbers. Any ideas??
Is it tuned? and rockers adjusted right? What type of headers? just a couple thoughts.
-Brian
Old Jan 13, 2006 | 04:43 AM
cmking26's Avatar
Yeah dyno tuned. Pasestter mids. Machine shop adjusted rockers.
Old Jan 13, 2006 | 06:39 AM
TQdrivenws6's Avatar
What springs? And are the valves floating?
Old Jan 13, 2006 | 06:53 AM
teke184's Avatar
any KR up top? specially with the RR.
are you injectors maxed out?
coil up to par to deleiver enough spark at high rpm?
Old Jan 13, 2006 | 08:09 AM
ABA383's Avatar
What was A/F ratio? timing? might want to post a graph if you can...
--Alan
Old Jan 13, 2006 | 09:02 AM
Dfetter84's Avatar
i feel your pain
check my threads
maybe you can get some ideas of what ive tried
my car still sucks too by the way
with a motha-F**kin built motor
Old Jan 13, 2006 | 05:06 PM
cmking26's Avatar
A/F 12.5-13.1. Springs are the cc I think 916. Tuner tweaked timing I don't what its at. He also said I had no kr issue. Injectors are no where near being maxed out. Its a brand new coil. I don't know, it runs excellent I just wanted more hp, maybe I should be happy and leave it alone.
Old Jan 13, 2006 | 10:45 PM
ABA383's Avatar
Those who have followed my posts know that I have little faith in dynos as I have laid down numbers all over the place on 3 different dynojets...If it feels good and the tune shows good A/F and timing, then hit the track when it opens and look at your mph...12.5-13:1 is fine...I'm at 13:1...
--Alan
Old Jan 14, 2006 | 12:38 AM
truedualws6's Avatar
Verify what valve springs you have and re-check the valve train. Post
the dyno graph if you can.
Old Jan 14, 2006 | 12:43 AM
cmking26's Avatar
I'll try to scan the dyno graph tomorrow. Could the clutch have been slipping or something since it was brand new?
Old Jan 14, 2006 | 04:04 PM
cmking26's Avatar
I have the dyno graph. If anyone wants to see it I can e mail it.
Old Jan 14, 2006 | 04:10 PM
97WS6SCharged's Avatar
Post the dyno on your car domain page and hot link it.
Old Jan 14, 2006 | 06:12 PM
96flame's Avatar
What catback are you running?? My 306 only put out 320rwhp until I open the cutout then its 346rwhp. Also the engine may put out more power once its broken in.
Old Jan 14, 2006 | 10:30 PM
speed_demon24's Avatar
I'm guessing by pacesetter mids, you mean their shorties. If you don't have longtubes, definatly get them, you will probably hit 350rwhp by just doing that.
