Low coolant light staying on. Tank/radiator full
Old Aug 15, 2003 | 08:56 AM
Shawn W's Avatar
Ever since putting in my new motor my low coolant light stays on even though the radiator and coolant tank are both full. Somtimes it kind of glows dimly and somtime it is full bright. I had this go bad on my old WS6 and took it to the dealer to fix and it was around $150.00 I would like to fix this myself since i am sure the sensor is probably only $30-40. Where is the sensor located? In the tank or in the top of the radiator?
Shawn
Old Aug 15, 2003 | 08:58 AM
Low coolant sensor
Old Aug 15, 2003 | 09:11 AM
EaC95Z28's Avatar
shawn- im sorry you paid that much. the part from gm is only 33 bucks or so. you can do it yoursefl. im getting ready to change mine tom!
Old Aug 15, 2003 | 09:12 AM
IXLR894Z28's Avatar
I don't know if this is the case, but I had a similar situation and it was the radiator cap. It had a leak, so the system did not stay pressurized whish triggered the low coolant light. Just a thought.
Old Aug 15, 2003 | 09:17 AM
Shawn W's Avatar
thanks guys. I was wondering if that square thing was the sensor but i was expecting it to be round and screw in. I will probably grap a new radiator cap also. This sensor has gone bad on every all 4 f-body cars i have had.
Shawn
bfmv13trivium
Jan 14, 2015 09:57 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
ro2207
Dec 4, 2014 06:18 PM
mspennyhughes
Nov 28, 2014 03:22 PM
