Low Coolant light and radiator fluid on battery
Old Dec 23, 2003 | 11:58 PM
ZZtop's Avatar
I have recently been getting a low coolant light and there is some fluid on the edge of the battery closest to the radiator cap. All the lines and connections there look dry and there is some slight fluid at the edge of the radiator cap. This has happend since I had the lower radiator hose pop off and lost ALL my fluid. I refilled the fluid and bled it using the top bleeder only. Could there be air int eh system? do I need to rebleed it using both bleeders? or is it possible the cap itself is not sealing? This is driving me nuts, any help would be great.
Old Dec 24, 2003 | 12:24 AM
S.J.S.'s Avatar
Get a new cap and if you have enough coolant in the radiator, just unplug the switch. They go out all the time and aint worth replacing. Everyone here just unplugs it. As long as you know that you have fluid and your not overheating, you dont even need the sensor.
Old Dec 24, 2003 | 12:27 AM
96 WS6's Avatar
You need to bleed BOTH bleeders. It is absolutely necessary or I garuntee you will have air in the lines especially since you blew the hose while the car was running and lost all the coolant.
Old Dec 24, 2003 | 12:31 AM
ZZtop's Avatar
Great, thanks guys. Will get a new cap and bleed BOTH bleeders tomorrow. Merry Christmas.
calaban
May 18, 2020 06:43 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
ro2207
Dec 4, 2014 06:18 PM
