low coolant light keeps coming on
Old Oct 15, 2003 | 05:16 PM
TOBsWS6's Avatar
My low coolant light keeps coming on . I have checked the coolant and just about all other fluids and can't get it to stay off. It is not running hot at all and is not on at all times. It goes on and off a couple of times and then stays on. I was wondering if anbody might have some ideas of what else to do. Where might the sensor be for this light?
Old Oct 15, 2003 | 05:22 PM
SloMofo's Avatar
Lightbulb
Prob just the sensor is bad. Common problem w/these cars. I just took the bulb for it out of my gauge cluster
Old Oct 15, 2003 | 05:25 PM
FastZinTennessee's Avatar
I'm having the same problem. So far I have found a bad heater core causing the coolant level to drop. Also, when I checked my coolant it would appear full, but when the thermostat opened it would drop.
I hope your case is diferent than mine, you might try simply unplugging your low coolant sensor and checking the fluid regularly.
Old Oct 15, 2003 | 05:29 PM
NVetro's Avatar
Prob just your radiator cap, its no big deal.
Old Oct 15, 2003 | 05:30 PM
Jon 97TA's Avatar
If it's the sensor(which it probably is), it's easy to replace. It's just under the fill cap on the radiator. Take the battery out so you got some room.
Jon
Jan 23, 2015 01:13 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
