Low Coolant Light Come On When I Use A/c Why??????????
Old Aug 20, 2005 | 08:04 PM
jayson smith's Avatar
Question Low Coolant Light Come On When I Use A/c Why??????????
WHEH AND ONLY WHEN I use my z/c my low water light comes on any idea why my water coolant is never low anyone eles had this problem
Old Aug 20, 2005 | 09:34 PM
jkucz31's Avatar
Re: Low Coolant Light Come On When I Use A/c Why??????????
ya i have the same problem but it comes and goes with or without the a/c on. i had a gm tech take a look and he says its a common problem with the low coolant sensor on 93-97 gm vehicles. you can see if when looking at the radiiator from the top a little square box on the left side about 3 inchs down.
Old Aug 20, 2005 | 11:02 PM
Are you sure about that? Go for a week without a/c and tell us what happens.
Old Aug 21, 2005 | 03:11 AM
97 WS6 T/A Conv's Avatar
If it's anything like our Subaru the engine coolant temp sensor was not reading the correct resistance for the PCM. I also would turn on the AC and I would throw a coolant temp circuit code 0015. I checked the fans, relays all were good. I changed out the sensor and no problems since.
I did like shoebox suggested. I cleared the code the first time (Autozone will read and clear the codes for free) then drove around for about 4 days or so then hit the AC again and 5 minutes later she threw a code. If that is your problem there's a coolant temp sensor near the bottom of the waterpump housing, that is the one the PCM uses for engine management.
There are 3 coolant sensors on the LT1. The waterpump for engine management. The radiator for coolant level and the head for the temp gauge. I do not know if they are all connected on the same circuit.
Old Aug 21, 2005 | 06:33 AM
i've gone for a month with the air off the first time i used it and never came on like i said only when i used the a/c. The temp sensor fell out on my once duno why and hasn't done it anymore so heck if i know
Old Aug 21, 2005 | 07:11 AM
slopokrodrigez's Avatar
Next time try unplugging the RAP module and see what happens. Check the ground on the post under the LH kick panel also.
calaban
May 18, 2020 06:43 PM
HectorM52
Jun 23, 2016 08:42 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
CaRParts102
Dec 6, 2014 08:45 AM
pologreen97z
Dec 2, 2014 10:42 AM
