Low Coolant Light but I'm full of Coolant
Old Aug 16, 2006 | 01:49 PM
Eddie Z-28's Avatar
I'm stumped here. I'm all filled up on coolant and the reservoir is full. Should I try replacing the sensor? If so how do I get to it and is it hard to do? Anyone else had this problem that could help me out with a possible solution?
Old Aug 16, 2006 | 01:53 PM
RicocheT's Avatar
Re: Low Coolant Light but I'm full of Coolant
I did yea.. The sensor was bad. Its right straight under the radiator cap and wasn't to hard to get to or replace. Basically an o-ring with some kind of clip on it if I remember correctly.
Old Aug 16, 2006 | 02:00 PM
Eddie Z-28's Avatar
You wouldn't happen to have a part number would you?
Old Aug 16, 2006 | 02:05 PM
Javier97Z28's Avatar
Moderator
Low coolant sensor is a typical failure. Remove the battery for easy access.
Image courtesy of shoebox:
Old Aug 16, 2006 | 02:07 PM
Eddie Z-28's Avatar
Thanks Javier.
EvilDCustoms's Avatar
how much did it cost and did u have to bleed a part of the coolant out to switch it out? email me with info if u can, i just unplugeed mine to get rid of that low coolant light. MuscaDamian@hotmail.com
Old Aug 16, 2006 | 04:26 PM
RicocheT's Avatar
I don't think they cost very much, and if you need to bleed, You can airlock it somewhat by leaving the radiator cap on and pulling it out... Some will come out but not much, if it doesn't airlock it'll just drain the radiator down to that level. If that happens just top it off and you should be good.
Old Aug 16, 2006 | 05:41 PM
LT1-TA's Avatar
just unplug it.. the light with turn off and code cleared...
Old Aug 16, 2006 | 08:27 PM
OBE1 95Z28's Avatar
This is always a good idea as you can look forward to replacing your head gaskets if you ever get a real coolant leak!
Old Aug 16, 2006 | 08:58 PM
Sparkz28ss's Avatar
that thing sucks...
just keep an eye on the temp..
Old Aug 16, 2006 | 09:22 PM
TripKidd's Avatar
hold on before you replace it... sometimes the little ballast just gets stuck. hit the tank right by the sensor with a good rap & you'll probably knock it loose.
calaban
May 18, 2020 06:43 PM
Jan 23, 2015 01:13 PM
Sandersen511
Jan 13, 2015 03:49 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Dec 4, 2014 11:56 AM
