Low Coolant Light
Low Coolant Light
I just finished a heads and cam install a week ago. Ever since then when I step on it hard, the low coolant light will pop on and stay on until I turn the car off. But if I am just driving normal around town the light does not come on at all. The coolant is full and I have bleed the system a couple of times. Any ideas what could be causing this?
Kevin C
Kevin C
I've had the same problem. I didn't add any mods, but I converted my 94 V6 to a 97 Z28 (it was a bitch because of the 3 year difference........just about EVERYTHING was different between those model years)
Everything works just fine....my coolant is full, but my low coolant light comes on every day. I have a brand new radiator and a brand new coolant sensor. Anyone else having the same problems we are having?
that sensor is known for going bad, if your coolant is full and your temps are running where they should be just ignore it, or i think you can unplug it and the light will go off, my light has been on for years
See the weird part is that my temps actually seem to be lower than before. I just havent paid it any mind
Mine does it also. Good amount of fluid and bled the system....still pops on. I had thought it turned off for good, but nope....came back on. The light is annoying and doesn't look cool to passengers in the car. I am going to replace the sensor.
Kevin C
Kevin C
. I think I'll unplug the sensor and drive on because my coolant levels are fine and the temperature is fine.
The sensor is located in the radiator, just below the fill neck. Shoebox has a photo here: http://shbox.com/1/low_coolant.jpg
Easy to get to once the battery is removed.
Jan 23, 2015 01:13 PM
