Low coolant light.
Old Jun 20, 2004 | 09:22 PM
JONEZ_Z's Avatar
Low coolant light.
After my heads and cam my coolant light stays on. I have purged the system prolly 5 times. The coolant wont come out of them unless i rev the motor. My temperature shows normal. Which sensor is the low coolant sensor? Am I hurting anything by driving it?
Old Jun 20, 2004 | 09:43 PM
OBE1 95Z28's Avatar
If your radiator is full when the engine is off and cold, then your coolant level sensor is giving you a false reading (common failure). First make sure you plugged it back in after the heads/cam install (sensor is located under the radiator fill neck). If it's plugged in and the wires aren't damaged, dain your radiator, pull the retaining clip off the sensor and remove the sensor. Clean the gunk out of the inside and then reinstall. If that doesn't fix it, replace the sensor.
Old Jun 20, 2004 | 10:50 PM
Steve0's Avatar
Where is this sensor located? I need to clean mine, I just got a light last week and i know my coolant isnt low.
Old Jun 20, 2004 | 10:55 PM
Steve0's Avatar
whoops, I have bad reading comprehension. Disregard that post.
Old Jun 20, 2004 | 10:56 PM
JONEZ_Z's Avatar
Ok ill try that. Thanks
Old Jun 20, 2004 | 11:01 PM
madhatter's Avatar
Just unlpug it. No code will be thrown. Just remember to check your coolant every once in awhile. Went through 2 sensors before I said "PHUQ IT!".
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
Fatdog2
Apr 27, 2015 10:32 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
