Low Coolant Light
Old Feb 23, 2004 | 10:38 AM
b-stevens's Avatar
Low Coolant Light
Should this light EVER come on? I dont seem to be losing coolant anywhere, no smoke out of the exhaust, no level drops, etc. But yet the light has come on. My car is not overheating at all. The temps rarely ever rise above 180. I'll flush and refill the coolant this weekend, but just curious as to whether or not i should drive it like this in the meantime.
Thanks in advance
Old Feb 23, 2004 | 10:51 AM
americanmusscle's Avatar
The sensor tends to go bad so you might want to check that. Its no biggie but it is anoying. A new sensor from jason cromer is like 30 or 40 bucks I believe.
Old Feb 23, 2004 | 10:56 AM
Hyperspeed97z28's Avatar
Its pretty common with our cars.. you can clean it or replace it...
Old Feb 23, 2004 | 11:37 AM
SnakeKilla's Avatar
I have this problemin my car, too!
Some people have told me that there are 2 coolan t sensors..
I've changed the one that is just outside of the water pump, Is there another coolant sensor?
Old Feb 23, 2004 | 11:41 AM
Brundle's Avatar
In the rad.
Old Feb 23, 2004 | 11:59 AM
EbeZ28's Avatar
Do a search on "Low collant light" or similar. The low coolant sensor is known to go belly up fairly regularly. Sounds like your sensor is crapping out. You can just unplug the thing (may on this board use this solution) or replace it. Sensor is here.
Old Feb 23, 2004 | 12:01 PM
AxeGrinder30thZ's Avatar
Yeah, I've heard it's a common stupid thing for our cars. I get it every now and then when I first start up the car and it's cold outside. I can start up the car and the light will be on. I shut it off and crank it up a minute later and it'll be gone.
Old Feb 23, 2004 | 12:02 PM
EbeZ28's Avatar
I may be way off, but I think the sensor in the water pump is for water temperature.
Old Feb 23, 2004 | 12:07 PM
Bingo! It's the temp sensor for the PCM.
Old Feb 23, 2004 | 12:26 PM
EbeZ28's Avatar
LOL...I think I saw that info on your website
Old Feb 23, 2004 | 01:15 PM
FacelessZ's Avatar
How about if you are losing coolant...its not leaking from anywhere that I can see, no white smoke out the back and no 'milky' oil...? At first I thought it was a blown head gasket but Im not seeing all the symptoms...bad intake gasket is all I can think of...
Sorry to jack the thread...didn't see a point in starting a whole other one...
Old Feb 23, 2004 | 07:01 PM
EbeZ28's Avatar
Check you weep valve on your water pump. If it's got a little liquid you could be evaporating it before it hits the ground. And it also means you water pump is probably going south as well.
Another thing to try is taking it for a long drive (enough to heat it up good) and then check the bottom of the radiator/front end for droplets of coolant.
I think they make that UV tracing stuff for coolant as well, might be easier that the previous two choices
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
