LOUD ticking noise from drivers side???
Old Jul 8, 2003 | 12:31 PM
Crazy8's Avatar
Question LOUD ticking noise from drivers side???
I put headers on a while back and there has been this ticking noise that sounds like it is coming just from the drivers side engine bay. I can only hear it when I am accelerating. Does anyone know what could be causing this? I check the header and I cant feel any leaks. Could it be the gasket?? Thanks for your help.
Old Jul 8, 2003 | 02:10 PM
Could be an exhaust leak. Look closely for any soot escaping at flange points.
Old Jul 9, 2003 | 08:21 AM
Joe K. 96 Zeee!!'s Avatar
Exhaust leak by the gasket most likely. Header bolts are known to loosen a bit over time. It's happened to me twice now. Both times the tick sounded almost mechanical, so I was a bit worried at first myself. It's not a must fix immediatly, but it can be pretty annoying over time.
Old Jul 9, 2003 | 10:00 AM
indy500ss's Avatar
Definatly a header exhaust leak, man I must have went through about 3 passenger side gasket before I got mine to stop. I finally stopped buying the cheap paper ones and got some copper felpros, no more problems. I would almost promise thats whats wrong with your car. Are you running the cheapy paper gaskets. Stage 8 header bolts would not be a bad investment after you swap the gaskets.
Old Jul 9, 2003 | 10:41 AM
96 WS6's Avatar
Could be a loose spark plug... for the longest time I thought I had a leak at the collector but I was inspecting the engine really closely running and I noticed the rear most plug was wiggling around a little bit. Turned out the hole is stripped... **** Might want to check yours out.
Old Jul 9, 2003 | 10:49 AM
1997rblckSS's Avatar
I agree with you,
Check your spark plugs, a loose plug makes the same type of exhaust leak tick noise.
Old Jul 9, 2003 | 10:55 AM
Crazy8's Avatar
Originally posted by 1997rblckSS
I agree with you,
That is what I thought it was originally. The back two spark plugs were wiggling around on the drivers side. So I tighted one and tried to do the other but it turned out to be cross threaded. I got that situation worked out and it still makes that same noise. So I am hoping that it is the gasket. The gasket that is on it now is a paper gasket but its not what came with the headers, guess I should of got the copper ones.
Old Jul 10, 2003 | 07:22 AM
Crazy8's Avatar
Well I found the problem. The gasket that was on it was supposed the wrong size. The hot air actually burnt a hole in the gasket and that is where it was leaking. I got the ones that Speed Inc. recommended for the install. I guess it figures, I really dont care for their service anyway.
karnykamaro
Feb 2, 2015 01:37 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Bando
Oct 7, 2002 07:36 PM
