loud popping sound
Old Dec 29, 2008 | 05:46 PM
97 green ta's Avatar
loud popping sound
I been having trouble with my car for some weeks now, thinking that its the opti,One of my friends came to test an extra optispark that i have laying around, he unplug the one that is on the car and plug the old one off the car, and plug one of the sparkplugs wires to the optispark and the other end to the sparkplug. He told me to crank the car, then he turn the rotor with the fingers and a big popping sound ,and there was vapor coming out of the intake, what do u think happen to the engine, it still cranks and seems ok. I appreciate any suggestions you can give me on my car.
Old Dec 30, 2008 | 03:24 PM
dbrunner2's Avatar
If I understand you correctly (the spare Opti had the 4-pin signal connector from the wiring harness plugged into it), that actually sounds like what's supposed to happen. When he turned the "off-car" Opti by hand, he produced a signal that made the engine computer think the engine was cranking, so it fired the ignition in order to start the car. It probably just ignited some fuel that was sitting in one of the cylinders with the intake valve open, so what you got was a weak backfire through the intake.
Old Dec 30, 2008 | 05:10 PM
red94chicken's Avatar
you obviously have great help. the spare opti apparently works. don't know what the condition of the cap and rotor are. you might want to actually install the spare opti to see if its the problem.
Old Dec 30, 2008 | 06:06 PM
Thanks for the help guys. I was scare something bad happen to the engine, and I think i found the problem, the plugs are fouled real bad.
Z28Freak86
Apr 30, 2024 05:37 PM
surreybrad
Jul 5, 2015 10:36 PM
SigSauer40
Exhaust System
Apr 29, 2015 09:02 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
JSK333
Sep 9, 2002 10:33 PM
