Lost Oil Pressure (Motor Didnt Turn Off) What Could It Be?
All is well with my problem. After I got the galley plugged and got it back together oil pressure is back to normal. got another 100 miles on the motor. I did rip the oil pan gasket since I didnt lower the pan AT ALL when removing or installing the timing cover. So I will need to lift the motor and replace the oil pan gasket. But for now its drivable, little leak every now and then. Thanks for all the help everyone.
Please tell me you replaced the cracked dummy shaft drive for the pump!
the leak got REAL annoying especially when I would smash the throttle a little oil would spill out and get on the exhaust.. leaving a burn oil smell ruins the whole experience. so I got in there today and dropped the pan and replaced the gasket. But as far as the oil pressure and plug, all is well with 1500miles on the motor now.
, I drove 30 miles with no oil pressure (or very little, rods spun) and my fuel never cut once.However as you said, it don't have one, period.
Jul 4, 2005 05:00 PM
