loss of power, thoughts?
Old May 2, 2007 | 04:01 PM
camzaro28's Avatar
I did the H/C almost 2 months ago, at first the car was real strong. Took it to the track with a bad fuel pump, and ran the 12.6 in my sig. Then I adjusted the valvetrain again, and after maybe a week I noticed it didnt feel as strong. Took it to get dynoed and it only laid down 264/290 . With bolt ons it did 273/304. Mind you dif dyno though.
Besides the dyno and track numbers I ran a few cars on the street before the H/C and got beat, then afterwards I was either keeping up or pulling them. Now they are beating me worse then when I had bolt ons.
I readjusted the valvetrain again, seemed to help a lil, but def not what I had when I first did the H/C.
What can I look into?
The car pulls fine, doesnt hesitate or miss a beat. Plugs look fine, as do the wires. Has a new pump with good pressure.
I have had a feeling that it could be knock/false knock? But I dont know how to tell if thats the case.
Please help.
Old May 2, 2007 | 04:05 PM
94NDTA's Avatar
Did you say it is still at the stock rev limiter?
Try degreeing the cam again?
Old May 2, 2007 | 04:23 PM
camzaro28's Avatar
Yeah still on stock shift points.
Could the cam be off somehow?
It had ALOT of tq down low, now it seems to have dissappeared : (
Old May 2, 2007 | 04:30 PM
94NDTA's Avatar
I have no idea, but it doesn't hurt to double check everything.
Old May 2, 2007 | 04:39 PM
BUBBA's Avatar
Did you say that it was tuned---because therein could lie your problemo if you aren't tuned.JMHO
Old May 2, 2007 | 04:45 PM
streetbad's Avatar
Check your exhaust. Might be a melted cat.,or a partition in your muffler folded over. Check your coil. -Tim
Old May 2, 2007 | 05:08 PM
camzaro28's Avatar
There is no cats on the car. longtubes, y-pipe, 18 bullet muffler. No restrictions.
The coil is a possibilty, how to check if that is the problem? There is no arcing, nor does it miss at WOT.
Well I was holding off on the tune due to money. But could that have anything to do with it having power then losing it over the course of a few days? I mean that tune hasnt changed since the H/C install but the car is slower.
Thanks thus far.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
maybe2fast
Mar 13, 2015 11:48 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
