Losing oil pressure under acceleration with 383
Old Jul 12, 2003 | 07:22 PM
WS6Formula's Avatar
What would cause oil pressure to drop under acceleration? I installed a mechanical gauge today to check it out, & under acceleration, as the RPMs come through about 3500-4000 or so, the pressure drops from 50ish to 25ish real fast. & then it slowly climbs back up to about 30.
What the heck could cause this? My mechanic that built the 383 said it was just the oil pressure sender, but I put the mechanical gauge on it to check & it says the same thing.
I'm pretty pissed at the mechanic, but what would cause it?
Thanks a lot
Steve
Old Jul 12, 2003 | 08:07 PM
97 RedSS's Avatar
Canton oil pan fixed my problem
Cody
Old Jul 12, 2003 | 08:14 PM
funina91ss's Avatar
you can buy a plate that goes between the oil pump and block that keeps the oil from climbing up the back of the pan. I take it if you rev it while setting still it goes up in PSI> ?What happens if you toll into the, rpms climb them high slowly?
Old Jul 12, 2003 | 09:02 PM
WS6Formula's Avatar
if I accelerate slowly, or just rev the engine siting still the oil pressure is fine, it's just while accelerating that it does it
Old Jul 14, 2003 | 04:59 AM
Dragonballz28's Avatar
you wouldn't have happened to put a high volume oil pump in would you? that would likey suck the stock oil pan dry.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
