losing coolant
Old Jun 2, 2013 | 10:41 PM
Glassguy06's Avatar
losing coolant
I have a 96 z28 that is losing coolant not radiator no white smoke no water in oil what could it be????
Old Jun 2, 2013 | 11:25 PM
slick1hunting's Avatar
how much are you losing and at what frequency? Any signs of water anywere or smell of coolant(especially with heater running)
Posted from Camaroz28.com App for Android
Old Jun 3, 2013 | 05:22 AM
Re: losing coolant
If the rubber overflow hose from the radiator fill neck to the reservoir has a crack in it, the radiator will never be full. As the radiator heats up and the coolant expands, the pressure is relieved by flowing the excess coolant to the reservoir. When the system cools down, the vacuum created pulls the coolant back out of the reservoir, and into the radiator. With a crack or pinhole in the overflow line, the vacuum is lost.
That would explain the coolant always being a bit low in the radiator, but would not explain a very large/frequent loss.
Old Jun 3, 2013 | 10:09 PM
Glassguy06's Avatar
Re: losing coolant
Thank you i found out it is a blown head gasket!!!!!!!
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
