Loose dowel pin?
Old Oct 21, 2004 | 11:32 PM
97Z-pimp's Avatar
Loose dowel pin?
Ok well i have had some really tought times getting the old dowel pin out of the cam im about to put into my car, but finally had a machine shop get it out. I purchased a new longer one from GM and it a a little (maybe 1-2 tenths) to narrow. It goes in pretty easy and i was wondering if maybe i could put some JB WELD in ther to make it stay? good idea or no? I have to have the done by the weekend. Thanks
Old Oct 21, 2004 | 11:41 PM
Spinner's Avatar
Re: Loose dowel pin?
Go ahead. Some green loctite will also do the trick.
Old Oct 22, 2004 | 11:01 AM
97Z-pimp's Avatar
Is there any pressure on the dowel pin while in the car, or is it just a reference point for the opti?
Old Oct 22, 2004 | 12:43 PM
TQdrivenws6's Avatar
By 1 to 2 tenths are you referring to .1-.2? or do you mean .0001-.0002? If its the first, I would not use JB weld, I would get the right pin. If its the second, you must have mic'd it and then just use some strong loctite.
Old Oct 22, 2004 | 02:40 PM
97Z-pimp's Avatar
Yes more like the later...i just used jb weld and it worked perfectly. thanks guys.
Novo
Jun 14, 2016 02:58 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
