Looks like Pacesetter has made some improvements
My new pacesetter LTs arrived yesterday and it looks like they have been listening to complaints. I was just comparing some pictures that Brent94Z posted a long time ago of his pacesetters to mine and it looks like they have made some subtle changes. I read quite a few posts about the #2 cylinder primary hitting the a/c line, but it looks like they rebent that tube. It now runs straight back out of the cylinder head instead of coming out at a slight downward angle like it used to.
New Style
http://www3.baylor.edu/~Eric_T_Evans/passenger1.JPG
http://www3.baylor.edu/~Eric_T_Evans/passenger2.JPG
Old Style
http://www3.baylor.edu/~Eric_T_Evans/oldstyle1.jpg (from Brent's pics)
I was also told that they revised the #1 primary tube to clear the steering shaft better, but it's too hard for me to tell from looking at pictures of old pacesetters. Maybe someone with the old style headers can compare them to the pictures that I have taken and post up if they see any difference.
New Style
http://www3.baylor.edu/~Eric_T_Evans/driver1.JPG
http://www3.baylor.edu/~Eric_T_Evans/driver2.JPG
I will be installing the headers this weekend along with a new set of poly motor mounts so that they won't hit the floorboard. I'll let you guys know if these changes have taken care of some of the complaints that I've been reading about, and I'll post some pics. So far I am very pleased with the quality of the headers especially for how much they cost. You just can't beat it. I had a set of Hooker LTs on one of my old cars and ground clearance was minimal, so I can't wait to see how these things look installed.
New Style
Old Style
New Style
Re: Looks like Pacesetter has made some improvements
Here is just a suggestion if you dont want leaks at the collector...
Have some 3 bolt flanges welded on to the headers and the y-pipe before you install them. The slip fit sucks.
I be it's gonna be a *itch and a half to put plugs on the pass. side. Also, looks like you can't use over-the-valve-cover plug wires either ... ?
I'd go with the jet-hots
i bought the pacesetter lt's also over the summer, they look just like the ones you just received of course i figured thats how they are suppose to look.
to be honest i really don't feel like they clear the steering column any better though, mine is practically rubbing the steering column and i don't have that plastic tubing around it either.
other than that the lt's have worked great so far. i didn't use the gaskets that came with them though since i have ported heads, i bought some from summit that actually worked out really well.
Originally Posted by DiabloGT
i have the old style and the otvc work? or are you talking about the new style?
I can swap my plugs in 30-45 minutes.
The fit is good on my headers, i didnt have any problems, they are the newer design. I think the major draw back to the Pacesetter is the slip fits, but i just weleded on the flanges and i dont have any problems with leaks.
Originally Posted by 357LT1
I'm glad they did come thru when they used my car for some R&D work a few months ago to check some issues out!
Ramiro
Ramiro
NOTE: I added another picture of the passenger header from a different angle to show how much space is between the #2 primary and the header flange.
