Looking for some quieter rockers???
Old Feb 19, 2009 | 07:21 PM
  #16
wrd1972's Avatar
Originally Posted by 96capricemgr
Try a different valvecover. LT4s got composite to dampen noise. Bet a thick cast aluminum cover would work some too.
If that is not good enough then consider swapping to an aluminum rocker.
I got the composite covers. There was a very slight reduction in noise. Not worth it if I had to do it again.
Old Feb 19, 2009 | 08:34 PM
  #17
2QUIK6's Avatar
Originally Posted by wrd1972
Many have told me that any aluminum rocker will be more quiet than the pro-mag. But not as strong.
Yeah, if I were still running the double springs I wouldn't want to run the aluminum rockers...but with the double springs there was not near as much noise as with beehives. With the lighter seat pressures of the beehives I'm not too concerned with the aluminum.
Old Feb 19, 2009 | 10:06 PM
  #18
CreatiVe2's Avatar
im running brand new motor with double springs and aluminum rockers, no metal shavings at all in oil filter during first 350 miles. (break in)
Old Feb 20, 2009 | 10:59 AM
  #19
krillformula's Avatar
I also got tired of the ticking from my promags so I ordered a set of scorpions and Im gonna install them soon before I take the car out in the spring.. I will let you know!½
Old Feb 20, 2009 | 11:09 AM
  #20
wrd1972's Avatar
I will most eagerly await your findings.
Old Feb 20, 2009 | 11:15 AM
  #21
2QUIK6's Avatar
Yes, me too...its going to be a few weeks before I even have time to get to change mine...
Old Feb 20, 2009 | 11:51 AM
  #22
me too x3 The car is on jackstands right now, getting the usual winter maintenance and a set of plugs etc.
I think somewhere in the middle of march or so we will find out if it did something good!
Old Feb 20, 2009 | 12:34 PM
  #23
WS6T3RROR's Avatar
I have already played this game back when I had le1's and a gm847 with the crane dual spring kit. The pro mags were loud, not just a little, people literally accused me of having a soild roller. So after awhile I got tired of hearing it and swapped to scorpions, as soon as I heard it on the first startup I couldnt believe how much difference it made the rockers were no longer audible inside the car. Sometime later I decided to put more cash into the heads run a bigger cam and do some intake work, and when to shaft mounts. It is pretty much dead silent now, the injectors and lifters and headers are what you hear with that setup.
Old Feb 20, 2009 | 02:20 PM
  #24
sounds promising, cause I cant stand engine noise..
Old Feb 20, 2009 | 07:05 PM
  #25
bolek's Avatar
WS6T3RROR, did you have to machine the heads or get different valve covers for Probe shafts?
Old Feb 20, 2009 | 07:11 PM
  #26
WS6T3RROR's Avatar
No but I dont have stock size or length valves, I have ebay cast aluminum valve covers that I had to do a little adjustment on. I had a set of proform covers sitting on it on the stand but i have a pontiac and a motor that says chevy wont do. I also do not have the probe rockers, I have t&d machine on my lt1 currently. I just know that Karl Ellwein has used a few probe shafts. I liked the set I have put on some dart pro 1's on a gen 1 chevy 383. Might talk to Karl about it on lt1's. I didnt have to do anything but adjust the shims for the stands on the pro 1's and then measure and order pushrods.
Old Mar 25, 2009 | 09:47 PM
  #27
2QUIK6's Avatar
Well today I had the time so I swapped out the promags with some Crane Golds...Not much difference so I think I may have some worn valve guides that is cause all the noise. It was a little quiter but there is a definite clacking in there and it has been getting progressively louder.
I did find one rocker with worn alignment tabs on it where it looked like it had popped off the valve tip so I suspect thats my real bad valve guide.
I have a brand new pair of LE1.5 heads that I guess I have a reason to swap on now.....
Old Mar 26, 2009 | 11:33 AM
  #28
Alright, good luck with the heads I hope the ticking goes away. BTW, my scorpions are in but it will take a week or two I think until I start it up.
Old Mar 26, 2009 | 10:02 PM
  #29
2QUIK6's Avatar
Well..today I drove it a few miles up the road to the parts store and it has quitened down alot. Still has one distinct clacker. Must have needed to oil up in all the right places, I did coat them down with oil after the install. Still going to swap heads in a week or two...the ones on there now where used and I think they are part of my long standing problem of not making the power they should have with the setup I have...
Old Mar 26, 2009 | 10:16 PM
  #30
Spartan7's Avatar
It could be a bad lifter that isn't pumping up, so the rocker is bouncing around on the valve. When I changed out my stock lifters for LS7's a bit of the ticking went away. Still watching your results though, I want to ditch these Pro Mags as well.
