looking for some ideas. starter issuses
Ok so Im not sure how to diagnosis this issue. the car has done this 3 times over the past 6 months. once when it was somewhat cold and he other times when the car was at temp. basicly you can click the key forward and nothing, the fuel pump primes, lights all work but the solenoid doesnt click. I tried jumping the solenoid and that turned over no problem. if I leave the car alone for a lil while (5mins to an hour) itll start right up no problem and continue to start for week/months. its kinda retarded, and tapping on the solenoid doesnt do a damn thing. could it still be the solenoid since I jumped the main power to the small connector and it clicked and turned over?
that was my first thought but I couldnt reproduce the problem or get it to be consistent.
The clutch switch was my first guess and I replaced that the first time it happened.
Nothing more annoying than an inconsistent Electrical problem! it hasnt left me stranded anywhere. Ill prolly just have to wait it out and see if it gets more frequent. thanks for the thoughts. I was just hoping I wasnt overlooking something obvious.
Next time it does it you can check to see if you are getting hot on the small post of the solenoid when cranking. If so, you can eliminate ignition switch, VATS, clutch switch, etc. It would definately be the solenoid.
not just hot, you need battery voltage at the small wire, I had high resistance in the ignition switch on my Iroc, and it lit a test light, but was only about 9.5 volts, not enough to trigger the solenoid
the ignition switch was going to be my next fix but since this is a random thing I dont want to go swapping parts until I can confirm the source of the issue. and the VATS has been programed out so that shouldnt be a problem.
well it might come on but I wouldnt know since that wast one of the wires I connected from the 97 wiring harness to my 91 harness. the "VATS" on the 91 side of the car havent existed for at least 6 years....
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
